[Geomoose-users] TMS tiles are offset. How to fix tile origin
Dan Little theduckylittle at gmail.com
Fri Jul 17 15:15:57 PDT 2020
Is this with GeoMoose 3?
On Fri, Jul 17, 2020, 15:10 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am attempting to set up GeoMOOSE to use a TMS tile layer that is in a
> custom projection.  I noticed that GeoMOOSE is not requesting the correct
> tiles.  I noticed a couple issues with the request.
> First,
> GeoMOOSE is requesting only tiles with a z=[0-8], when it should be
> requesting z=[0-10]
> Second,
> The tile origin on Mapcache is set beginning in the lower left corner.  In
> GeoMOOSE the requested tile origin begins in the upper left corner.
> Third,
> The requested tiles are offset.  At z=0 GeoMOOSE is requesting tiles
> around 150,150 while it should be requesting tiles around 0,0.  At z=8
> GeoMOOSE is requesting tiles around X=39991 Y=38942 (lower left) to
> X=40240 Y=38630 (upper right).
> Questions:
> I think it may be very possible that if I resolve the first and second
> issue then the third issue will resolve itself.   If anyone knows how I can
> fix the Z offset, and the tile origin please let me know.
> *Note  The mapcache WMTS service works fine in ArcGIS.
> Thanks
> Sincerely,
> *Mark Volz, GISP*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200717/242c3df3/attachment.html>
More information about the Geomoose-users mailing list
