[Geomoose-users] GeoMoose 3 - AGS Legend Support
    Brent Fraser
    bfraser at GeoAnalytic.com
    Fri Jun 12 12:05:00 PDT 2020
So much documenting to do...
 AFAIK, GM3 has two kinds of legends: static and dynamic (my terms)
 Static you add to the mapbook for vector layers as type="html" (so you
code CSS styling in the mapbook), or type="img" and you supply a graphic
file.
 Dynamic is only for map-source types of "mapserver" (and maybe "wms"?) and
the legend will be created on the server composed of the rendered features.
 I think GM only supports image legends, not JSON ,etc.
 So currently, GM 3 does not support a dynamic (data server-generated)
legend for vector data sources.
 Brent
 -------- Original Message --------
> From: "Jim Klassen" <klassen.js at gmail.com>
> Sent: June 12, 2020 12:37 PM
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] GeoMoose 3 - AGS Legend Support
> In GeoMoose, vector layers are styled and rendered in the browser rather
than by the server. Thus, I would expect legends for ags-vector to behave
the same as any other vector layer.  If that isn't currently the case for
ags-vector then that is an oversight/bug. On 6/12/20 1:19 PM, Brent Fraser
wrote: > Hi Chris, > > I haven't looked into AGS legend yet, but my guess
is no, neither > type="ags" or type="ags-vector" support legends. > > A
longer answer: > > Both type="ags" and type="ags-vector" are for accessing
ArcGIS Servers > with MapServer endpoints (they do not access FeatureServer
endpoints) > Responding to Legend requests is an option when setting up the
AGS server > (and it looks like most don't?). And AGS servers can serve
different > formats of legends >
(https://developers.arcgis.com/rest/services-reference/legend-map-service-.h
 > tm) and different kinds >
https://developers.arcgis.com/rest/services-reference/query-legends-map-serv
 > ice-.htm). > > > Best Regards, > Brent Fraser > > > -------- Original
Message -------- >> From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>> Sent: June 12, 2020 9:20 AM >> To: "GeoMoose Users"
<geomoose-users at lists.osgeo.org> >> Subject: [Geomoose-users] GeoMoose 3 -
AGS Legend Support >> >> Is there support for AGS legends in GeoMoose 3?
Particularly for vector >> layers with multiple classes where the meaning
of the symbology isn't >> readily >> apparent. >> >> I tried turning on the
legend for the ags services in the demo > (railroads >> and the Nat Geo
world map) and was unsuccessful. >> >> Best, >> Chris >> >> -- >> Chris
Hughes >> >> GIS Analyst >> Lincoln County Surveyor Department >> 880 NE
7th St. l Newport, OR 97365 >> Tel: (541) 574 1283 >>
_______________________________________________ Geomoose-users mailing >
list Geomoose-users at lists.osgeo.org >
https://lists.osgeo.org/mailman/listinfo/geomoose-users > > >
_______________________________________________ > Geomoose-users mailing
list > Geomoose-users at lists.osgeo.org >
_______________________________________________ Geomoose-users mailing list
More information about the Geomoose-users
