[Geomoose-users] GeoMoose 3 - AGS Legend Support
Christopher Hughes
chughes at co.lincoln.or.us
Fri Jun 12 16:09:32 PDT 2020
Thanks for all the feedback!
HTML legends look like they may be a viable option that I need to explore
more.
There may be a bug/oversight as I haven't been able to get the legend
working for the demo's ags-vector layer
that has its style declared in the map-source (or perhaps the map-source
needs to be configured in a certain way
for the legend to show).
Best Regards,
Chris
On Fri, Jun 12, 2020 at 1:44 PM Jim Klassen <klassen.js at gmail.com> wrote:
> I think your use of static/dynamic is fine.
> My point is, with a little creativity, there is a lot of potential power
> in the 'static' legends beyond what is shown in the demo. And it might be
> worth documenting that to get people thinking about what they could do with
> it.
> I'm be happy for the Apache trick to land in the docs. I've been using
> MapServer that way for ~15 years. Only reason it isn't in the docs already
> is when I first came up with it, I was told it was too complicated, so I
> dropped it.
> On 6/12/20 3:15 PM, Brent Fraser wrote:
> > See comments below
> > -------- Original Message --------
> >> From: "Jim Klassen" <klassen.js at gmail.com>
> >> Sent: June 12, 2020 1:50 PM
> >> To: bfraser at GeoAnalytic.com, geomoose-users at lists.osgeo.org
> >> Subject: Re: [Geomoose-users] GeoMoose 3 - AGS Legend Support
> >> I think you are basically correct. A couple of minor points:
> >> Keep in mind that the legend graphic file could be any URL that returns
> > an image and doesn't necessarily need to point to a static file on the
> web
> > server. So, for example, it could be a legend or preview imaged
> generated
> > from a WMS request (or other URL). However, I suspect that you are
> correct
> > that it will be 'static' as in it will only be loaded once per GeoMoose
> > session rather than updated as the map view changes.
> >> Also, an HTML legend can be all sorts of creative with what is included
> > (<a>, CSS background-image: url(...), etc.).
> > Yeah, static isn't a very good term, but I was trying to illustrate
> that
> > the legend will not change on a pan/zoom as it could with
> type="mapserver"
> > or "wms" if there a zoom sensitive layers set up on the data server.
> >> The layer types 'mapserver' and 'mapserver-wfs' are just shortcuts for
> > 'wms' and 'wfs' where GeoMoose does the
> url='/cgi-bin/mapserv?map=<file>&'
> > substitution for you (using the values from config.js). (Long ago, the
> > 'mapserver' layer type actually made a Mapserver 'mode=map' request, but
> it
> > has been using WMS behind the scenes since at least GeoMoose 2.6.)
> > Yes, and the move to standard protocols (like wms, wfs) is a good
> thing.
> > In fact to test wfs I just created a mapsource like so:
> > <map-source name="wfs-polygons" type="wfs" >
> > <url>http://localhost/cgi-bin/mapserv.exe</url>
> > <param name="map"
> > value="C:/ms4w/apps/gm3-demo-data/demo/parcels/parcels.map"/>
> > <param name="typename" value="ms:parcels"/>
> > <layer name="default" title="wfs Polygons">
> > But there may have been some problems with some Mapserver versions in
> the
> > past (search the GM source for "wgs84Hack")
> >> Rant/aside/tangent:
> >> Personally, I don't like the mapserver layer types and think that this
> > path rewrite stuff is better done on the web server so access is
> consistent
> > with other WxS clients (like QGIS).
> >> I have Apache setup with Actions and RewriteRules so that
> > '/datasets/some.map' -> '/cgi-bin/mapserv' with the MS_MAPFILE
> environment
> > variable set to '/srv/datasets/some.map' behind the scenes.
> >> This also allows for using Apache to manage access to individual
> mapfiles
> > as well as separates mapfiles in the logs because every request isn't
> just
> > /cgi-bin/mapserv with the actual mapfile being potentially hidden in a
> > POST. This also uses Apache to be sure the .map file exists and is under
> > the /srv/datasets tree before executing the request (so things like '..'
> in
> > the path don't let people tell mapserver to access other places on your
> > server).
> >> This does require a patch to mapserver or the setting the
> > "ows_onlineresource" metadata in every mapfile so the links in
> > GetCapabilites responses point to the right spot.
> >> Something like:
> >> <Directory "/usr/lib/cgi-bin">
> >> AllowOverride None
> >> Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
> >> # Only allow specified CGI-BIN files
> >> Require all denied
> >> # Mapserver
> >> <Files "mapserv">
> >> Require all granted
> >> SetEnv MS_ERRORFILE "stderr"
> >> SetEnv MS_MAP_NO_PATH "true"
> >> RewriteEngine on
> >> RewriteCond %{env:REDIRECT_HANDLER} ^mapserver
> >> RewriteCond %{PATH_INFO} ^/datasets/(.*)
> >> RewriteRule .* -
> > [C,env=MS_MAPFILE:/srv/datasets/%1]
> >> RewriteRule .* - [L]
> >> RewriteRule .* - [F]
> >> </Files>
> >> </Directory>
> >> <Directory "/srv/datasets/">
> >> Require all denied
> >> Action mapserver /cgi-bin/mapserv
> >> AddHandler mapserver .map
> >> <Files "*.map">
> >> Require all granted
> >> </Files>
> >> </Directory>
> >> Alias /datasets/ /srv/datasets/
> > Ooo! Nice! How about finding a spot in the docs for that?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200612/53085ef3/attachment.html>
More information about the Geomoose-users
