[Geomoose-users] Heads-up for MapServer users: start removing all references to DUMP in your mapfiles now...
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Apr 8 09:33:17 PDT 2021
(sending this to the GeoMoose community as many use MapServer to publish
their services)
Hello everyone!
This is a big heads-up, that the upcoming MapServer 8.0 release (and the
current MapServer source code if you compile from the GitHub
[unreleased] source as of today) will cause an error to be thrown if
your LAYER contains the DUMP parameter:
loadLayer(): Unknown identifier. Parsing error near (DUMP): line xxx
So it would be smart now to review all of your mapfiles to make sure
that any references to DUMP in your layers are commented or removed.
(DUMP was first deprecated back in the 6.0 release, and using LAYER
METADATA is required instead)
For example, here is an example that uses METADATA to expose (or dump)
all attribute fields for a layer that is served through WFS:
LAYER
NAME "continents"
METADATA
"wfs_title" "World continents"
"gml_include_items" "all"
"gml_featureid" "ID"
"wfs_enable_request" "*"
END
*the next MS4W release will definitely contain this change, so please be
sure to start removing DUMP from your mapfiles now...
Thanks all!
-jeff
Thank-you for using MS4W.
"MS4W: open doors as well as windows"
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the Geomoose-users
