[Geomoose-users] TMS layers in GeoMOOSE 3.x
    Jim Klassen
    klassen.js at gmail.com
    Fri Dec 17 12:01:42 PST 2021
The part I'm not sure about is if there is still support for custom tile
grids.  At first glance it looks like only the default grid is supported
(I don't see anything in GeoMoose 3 to override the OpenLayers
tileGridFunction or specify a different tileGrid).
On 12/16/21 12:42 PM, Brent Fraser wrote:
> Hi Mark.
>   i did some TMS testing a while back and used:
>   <!-- - - - - - - -  TYPE = "xyz -> TMS"   - - - - - - - - - - - - -->
>     <map-source name="TMS-tile" type="xyz">
>         <layer name="imagery"/>
> <url>http://localhost/gm3-demo-data/demo/tiles/TMS/MNDAKO075061_s3/{z}/{x}/{-y}.png</url>
>     </map-source>
>   Note the *{-y}* .  And the tiles I used are not in the standard gm3
> demo data; I just put my test data there on my local machine.
> Best Regards,
> Brent Fraser
> *From*: "Mark Volz" <MarkVolz at co.lyon.mn.us>
> *Sent*: 12/16/21 11:12 AM
> *To*: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
> *Subject*: [Geomoose-users] TMS layers in GeoMOOSE 3.x
> Hello,
> Can we add TMS layers to GeoMOOSE 3.x? In the older version of
> GeoMOOSE I had used TMS to connect to MapCache.  Please let me know if
> I can access TMS layers and if I should do something different.
> Thank You
> GM 2.x code to access TMS:
> <map-source name="Picto2020BackgroundTMS" type="tms"
> projection="EPSG:103749" tiled="true" width="512" height="512"
> units="ft" transitionEffect="resize" tileOrigin="new
> OpenLayers.LonLat(436450.000000,80000.000000)">
>         <layer name="LyonPictoPhotos2020"/>
> <url>https://geomoose.lyonco.org/lyonmapcache/tms/</url>
> <type>"jpg"</type>
> </map-source>
> Sincerely,
> *Mark Volz, GISP*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20211217/549ddc95/attachment.html>
More information about the Geomoose-users
