[Geomoose-users] TMS layers in GeoMOOSE 3.x
Brent Fraser
bfraser at geoanalytic.com
Mon Dec 20 10:08:55 PST 2021
Hi Mark,
Regarding Issue #1 (the tile id problem), try using
<url>https://geomoose.lyonco.org/lyonmapcache/tms/1.0.0/LyonPictoPhotos2020@GoogleBingArcGISCompatible/{z}/{x}/{-y}.jpg</url>
Note the {x}/{-y} order and the minus sign.
As for Issue #2 (the cross-origin problem), Jim would be the expert. If you are in control of the tile server (and it is running Apache as the web server) you could try adding
Header set Access-Control-Allow-Origin "*"
to the configuration (as an example see https://github.com/geomoose/gm3-demo-data/blob/c29e41a341a300532984a4daeb26fa14bddc156a/docker/etc/000-default.conf#L14 )
Other possible solutions are:
- serve the GeoMoose page from the same origin as the tiles, or
- put a proxy on the GeoMoose page server to get the tiles when requested and pass them to the Geomoose page.
Best Regards,
Brent Fraser
Sent: 12/20/21 8:43 AM
To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] TMS layers in GeoMOOSE 3.x
Brent and Jim,
Thank you for your replies.
I am using MapCache to serve out imagery in Web Mercator (GoogleBingArcGISCompatible). The Web Mercator tiles are working correctly in ArcGIS as well as QGIS when using WMTS. Unfortunately, I am still having a couple issues:
Issue 1:
*GeoMOOSE is requesting a tile that it out of range. I am not sure what is causing this issue:
GeoMOOSE is working with other XYZ tile servers such as OpenLayers.
MapCache is working with ArcGIS and QGIS clients.
The tiles requested and served are 256*256.
I think the tiles should be working however I am still getting an error that my tiles are out of range even after I checked to make sure that I did not swap the X and Y. One error is that MapCache is reporting tile y=189759 is not within 334028 to 334954.
Issue 2:
*Firefox is reporting that a cross-origin request is blocked.
Please let me know if you might know how I can fix these problems. For reference I the public server and configuration information is below.
Thank You!
The public server is:
GeoMOOSE Configuration:
<map-source name="Picto2020BackgroundTMS" type="xyz" transitionEffect="resize">
<layer name="LyonPictoPhotos2020"/>
<url>https://geomoose.lyonco.org/lyonmapcache/tms/1.0.0/LyonPictoPhotos2020@GoogleBingArcGISCompatible/{z}/{y}/{x}.jpg</url>
<type>"jpeg"</type>
</map-source>
MapCache Configuration:
<grid name="GoogleBingArcGISCompatible">
<metadata>
<title>GoogleBingArcGISCompatible</title>
<WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
</metadata>
<extent>-20037508.3427892480 -20037508.3427892480 20037508.3427892480 20037508.3427892480</extent>
<srs>EPSG:3857</srs>
<srsalias>EPSG:900913</srsalias>
<units>m</units>
<size>256 256</size>
<resolutions>156543.0339280410 78271.51696402048 39135.75848201023 19567.87924100512 9783.939620502561 4891.969810251280 2445.984905125640 1222.992452562820 611.4962262814100 305.7481131407048 152.8740565703525 76.43702828517624 38.21851414258813 19.10925707129406 9.554628535647032 4.777314267823516 2.388657133911758 1.194328566955879 0.5971642834779395 0.29858214173896975 0.149291070869484875</resolutions>
</grid>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20211220/45713d5e/attachment.html>
More information about the Geomoose-users
