[Geomoose-users] Vector Editing info
Brent Fraser bfraser at geoanalytic.com
Wed Jan 6 10:32:44 PST 2021
Hi all,
Big thanks to Dan for working on the Vector Editing!  For those interested in trying out this work-in-progess, I've started a doc page on the wiki (https://github.com/geomoose/gm3/wiki/Doc-In-Progress:-Editing-Vectors-Using-GeoServer-with-GeoMOOSE) (it will be move to the doc repo when we do a release with this functionality).
To get the code (if you are up to using the NodeJS environment), follow the instructions on https://geomoose.github.io/gm3/quickstart.html, or https://geomoose.github.io/gm3/install_on_windows.html
but using a slightly modified workflow for getting Dan's Pull Request :
mkdir gm3_vector_edit
git clone https://github.com/geomoose/gm3.git gm3_vector_edit
cd  gm3_vector_edit
git remote add upstream https://github.com/geomoose/gm3.git
git pull upstream pull/620/head
Thank again!
Brent Fraser
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20210106/a4429115/attachment.html>
More information about the Geomoose-users mailing list
