[Geomoose-users] Formatting the results tab to include number
Jim Klassen
klassen.js at gmail.com
Wed Nov 10 08:18:42 PST 2021
This works for me for and I get 70.7 (it was 2 digits by default so I couldn't use that as a test).
{{ properties.ACRES_POLY|fix>1 }}
Keep in mind the templates tend to get cached by the browser somewhat aggressively so you might have to clear cache/etc. to see changes.
On 11/10/21 10:02 AM, Mark Volz wrote:
> James, and others
> I was able to remove the ??? value from blank results by specifying how blanks should be handled such as: <div class="item"><label>Property Address:</label> {{ properties.TXPADR1|blank>N/A }}</div>. Thank you for your help. Unfortunately, I am still having trouble trying to figure out how to properly call the toPrecision function.
> Thanks!
> Parcels.html
> var context = { num: {properties.TXDEED}};
> var template = "{{num|call>toPrecision>5}}";
> var result = Mark.up(template, context);
> <div class="identify-result">
> <div class="feature-class">Parcel (remote template14)</div>
> <div class="item"><label>PIN Number:</label> {{ properties.Parcel_ID }}</div>
> <div class="item"><label>Rounding Deeded Acres (works):</label> {{ properties.TXDEED|round}}</div>
> <div class="item"><label>Deeded Acres inline precision (does not work):</label> {{ properties.TXDEED|call>toPrecision>2}}</div>
> <div class="item"><label>Deeded Acres by calling variables above (does not work):</label> {result}</div>
> <div class="item"><label>Deeded Acres by calling variables inline inline var(does not work):</label> {var context = { properties.TXDEED}; var template = "{{num|call>toPrecision>5}}"; Mark.up(template, context);}</div>
> </div>
>> Look at choose and/or if for ??? and fix for formatting numbers.
>> https://github.com/adammark/Markup.js
>> On Nov 10, 2021, at 07:57, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Hello,
>> I would like to change the format of my results tab so that:
>> ? Display only two digits for floating point value. We could do this in older versions of GeoMOOSE by specifying a precision [item name="Acres" precision=2]
>> ? When a value is blank or null change the result from ????? to an empty text. For example not all of our parcels have property addresses.
>> Thank You!
>> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
