[Geomoose-users] Identify error in gm380
Christopher Hughes chughes at co.lincoln.or.us
Thu Oct 14 09:22:43 PDT 2021
One thing that can be helpful for debugging, is that you can point your
index.html to geomoose.js instead of the minified geomoose.min.js.
This should give you some more useful errors that may give you a better
idea of what's going wrong.
You can also compare your mapbook.xml to the current demo (where the
identify is working). Sometimes there are syntax changes
to fix bugs or add enhancements, which can cause issues if they aren't
incorporated into your build.
Best of luck,
Chris
On Wed, Oct 13, 2021 at 5:14 AM Richard Camejo <rfcamejo at gmail.com> wrote:
> Hi, I have installed gm380 successfully.
> The "identify" tool does not work.
> The error it produces is the following:
> TypeError: i is null
>     r https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     getQueryableLayers https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     value https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     query https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/services/identify.js?v=1:81
>     startQuery https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:83
>     value https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:83
>     Iu https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     unstable_runWithPriority https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:62
>     Hi https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     mu https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     Ki https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     Xi https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     pu https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     enqueueSetState https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:54
>     setState https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:46
>     onStateChange https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     y https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     r https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     setFeatures https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     value https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     dispatchEvent https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     finishDrawing https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     handleUpEvent https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     handleEvent https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:27
>     handleEvent https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     handleMapBrowserEvent https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:38
>     handlePointerUp_ https://sig.rocha.gub.uy/gm380/htdocs/geomoose/dist/geomoose.min.js?v=1:83
> I have another installation in production with gm370 (https://sig.rocha.gub.uy) in which it works perfectly from GeoServer.
> I appreciate any help.
> Greetings
> Richard.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20211014/bfb48293/attachment.html>
More information about the Geomoose-users mailing list
