[GeoMoose-users] exact search
flavio rigolon flavio.rigolon at gmail.com
Thu Dec 1 05:18:21 PST 2022
Il giorno mer 30 nov 2022 alle ore 21:46 Dan Little
<theduckylittle at gmail.com> ha scritto:
> Hi Flavio!
Hi Dan, thank you very much for your tests and answer
> I'm looking into this. We do not have a `eq-str` operator, there is likely an error in the Javacript console and the operation isn't finishing. That's why you're seeing the "spinner" that never stops.
Ok, I've found the 'eq-str' operator in the 2.* version doc where I
see that the 'eq' is for numeric data and 'eq-str' for string. So I
thought that parameters were ok for 3.* version too.
> Testing against the demo, I am able to query using `eq` as the operator without any exceptions.
> `eq` should be the correct operator. Can you use the `eq` operator and post the contents of the request body? If that looks normal then we may need to look at what's in the Mapfile.
Using the 'eq' operator in Geomoose I obtain this error:
Error
msWFSGetFeature(): WFS server error. FLTApplyFilterToLayer() failed
msPostGISLayerWhichShapes(): Query error. Error executing query. Check
server logs
and checking the postgresql log I've found this:
ERROR:  operator does not exists: character varying = integer at character 572
HINT:  No operators found with given name and argument types. It may
be necessary to convert the indicated types.
INSTRUCTION:  select
"gid"::text,"foglio_id"::text,"mappale"::text,"tipobene"::text,"numero_repertorio"::text,"vincolo"::text,"ex_num_rep"::text,"Note"::text,"tooltip"::text,"Controllo"::text,"AnnoRep"::text,ST_AsBinary(ST_Force2D("the_geom"),'NDR')
as geom,"gid"::text from particella_patrimonio where "the_geom" &&
ST_GeomFromText('POLYGON((1684664.20503714
5037777.87184059,1684664.20503714 5049622.92254882,1692749.83495607
5049622.92254882,1692749.83495607 5037777.87184059,1684664.20503714
5037777.87184059))',find_srid('','particella_patrimonio','the_geom'))
and ((("foglio_id" = 2) and ("mappale" = 23)))
many thanks again!
flavio
/"\  ASCII Ribbon Campaign
\ /  Respect for low technology.
 X  Keep e-mail messages readable by any computer system.
/ \  Keep it ASCII.
More information about the GeoMoose-users mailing list
