[GeoMoose-users] WFS identify is GeoMoose using MapServer
Brent Fraser bfraser at geoanalytic.com
Mon Jan 2 14:14:05 PST 2023
Interesting.  When I change the mapsource type from "wfs to "mapserver-wfs", Mapserver returns
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 8.1-dev OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF -->
<BODY BGCOLOR="#FFFFFF">
msCGILoadMap(): Web application error. CGI variable "map" fails to validate.
</BODY></HTML>
somewhat reasonable since GeoMoose adds a
&MAP=C:/ms4w/apps/gm3-demo-data/undefined
to the request.
Sent: 1/2/23 2:59 PM
To: bfraser at geoanalytic.com
Cc: Jeff McKenna <jmckenna at gatewaygeomatics.com>, GeoMoose Users <geomoose-users at lists.osgeo.org>
Subject: Re: [GeoMoose-users] WFS identify is GeoMoose using MapServer
Thi is actually a MapServer bug that's been around for a while. MapServer doesn't do well when querying in 3857 and the underlying data is in another projection. So we have an option to use the "wgs84Hack" (internal name in the code). This is enabled when the map-source type is set to "mapserver-wfs".
On Mon, Jan 2, 2023 at 3:55 PM Brent Fraser <bfraser at geoanalytic.com> wrote:
Hi Jeff (and others),
I'm in the process of testing WFS in GeoMoose and thought I would make WFS requests to the demo site at demo.mapserver.org.  So in accessing the cities layer (https://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities) it displays OK in GeoMoose even though the display SRS is EPSG:3857.
However the Identify operation fails. Mapserver returns
<?xml version='1.0' encoding="UTF-8" ?>
<wfs:FeatureCollection
xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/WFS-basic.xsd
http://mapserver.gis.umn.edu/mapserver https://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=ms:cities&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:null>missing</gml:null>
</gml:boundedBy>
</wfs:FeatureCollection>
when the request sent (via POST) is
<GetFeature xmlns="http://www.opengis.net/wfs"
service="WFS"
version="1.1.0"
outputFormat="text/xml; subtype=gml/2.1.2"
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Query typeName="ms:cities"
srsName="EPSG:3857">
<Filter xmlns="http://www.opengis.net/ogc">
<Intersects>
<PropertyName>geom</PropertyName>
<Polygon xmlns="http://www.opengis.net/gml">
<exterior>
<LinearRing>
<posList srsDimension="2">
 -10382797.7354368  5615179.747957421
 -10382797.7354368  5615332.622013991
 -10382644.86138023 5615332.622013991
 -10382644.86138023 5615179.747957421
</posList>
</LinearRing>
</exterior>
</Polygon>
</Intersects>
</Filter>
</Query>
</GetFeature>
Note the srsName in the request (3857 is not listed in the MapServer GetCapabilities doc).  When asking for the features for display GeoMoose sends a BBOX (3857) in the request.  When requesting feature(s) in Identify, it sends only the Intersects filter in the above XML.
So I'm not sure if this is a Mapserver configuration issue or a bug/Issue in GeoMoose.
Your thoughts?
Thanks!
Brent Fraser
GeoMoose-users mailing list
GeoMoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20230102/380eab72/attachment.htm>
More information about the GeoMoose-users mailing list
