[GeoMoose-users] One to Many Join - GeoMoose 3
Christopher Hughes
chughes at co.lincoln.or.us
Fri Jan 6 15:20:10 PST 2023
Thanks for the example code! That makes it a lot easier to adapt it.
Chris Hughes
GIS Analyst
Lincoln County GIS Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
Sent: Friday, January 6, 2023 1:31 PM
To: Christopher Hughes <chughes at co.lincoln.or.us>; GeoMoose Users <geomoose-users at lists.osgeo.org>
Subject: Re: [GeoMoose-users] One to Many Join - GeoMoose 3
If you want to pursue the joined table approach, I did some searching of my archived projects and found this method of doing a join in the DATA object (with some commented out experiments):
CONNECTIONTYPE OGR
CONNECTION 'T:/GeoData/Parcels/Alberta/t_505033.shp'
DATA "SELECT * FROM t_505033 LEFT JOIN 'ODBC:Parcels_Rural,basic'.basic ON t_505033.PID=basic.PID"
## DATA "SELECT * FROM (t_505033 LEFT JOIN 'ODBC:Parcels_Rural'.basic ON t_505033.PID=basic.PID) LEFT JOIN 'ODBC:Parcels_Rural'.estate ON basic.LINC=estate.LINC"
## DATA 'SELECT * FROM t_505033 LEFT JOIN "ODBC:Driver={Microsoft Access Driver (*.mdb)};Dbq=G\GeoData\Parcels\Alberta\t_505033.mdb".basic ON t_505033.PID=basic.PID'
I used the ODBC driver because the other table was in an MS Access .mdb. You may need to do some experimenting to get the syntax for joining a shp file to a dbf.
Brent
From: "Christopher Hughes" <chughes at co.lincoln.or.us>
Sent: 1/6/23 2:11 PM
To: GeoMoose Users <geomoose-users at lists.osgeo.org>, "bfraser at geoanalytic.com" <bfraser at geoanalytic.com>
Thanks for the suggestion! I hadn't thought of approaching it that way.
Chris
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
From: GeoMoose-users <geomoose-users-bounces at lists.osgeo.org> on behalf of Brent Fraser <bfraser at geoanalytic.com>
Sent: Friday, January 6, 2023 8:32 AM
Subject:Re: [GeoMoose-users] One to Many Join - GeoMoose 3
Chris,
It's an interesting problem. Depending on how you want the user access and visualize the data, where could be other solutions. One solution would be to would be to write a server-side script (in Python, PHP, etc) to take an ID parameter and return an HTML page of records of the join table. You could put a link in each of the GeoMoose result rows to reference the script, something like
https://myserver/getBuildings.php?parcel_id=2102<https://myserver/getBuildings.php?parcel_id=2102>
https://myserver/getBuildings.php?parcel_id=<https://myserver/getBuildings.php?parcel_id=2102>4037
Clicking on one of these would bring a list of "joined" records in a new page or popup.
Brent
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20230106/df282c47/attachment-0001.htm>
More information about the GeoMoose-users
