[GeoMoose-users] Print Layouts
Christopher Hughes chughes at co.lincoln.or.us
Mon Mar 6 08:49:56 PST 2023
I'm not sure what's going on for you. When I copy and paste that code into my application the defaults are overridden and I just have the single A4 template.
If I were you I might try recreating the demo on 3.10 and adding custom layouts there. If that works you could compare the demo code in the app.js to your own to see what's changed.
Chris Hughes
GIS Analyst
Lincoln County GIS Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
Sent: Sunday, March 5, 2023 11:59 PM
To: Christopher Hughes <chughes at co.lincoln.or.us>; geomoose-users at lists.osgeo.org <geomoose-users at lists.osgeo.org>
Subject: AW: Print Layouts
thanks for the reply, this is how it worked in the old version
my code in the app.js looks like this:
var custom_layouts = [
    label: 'A4 Quer',
    orientation: 'landscape',
    page: 'a4',
    units: 'mm',
    elements: [
            type: 'text',
            size: 15, fontStyle: 'bold',
            x: 10, y: 12, text: '{{title}}'
            type: 'map',
            x: 10, y: 15,
            width: 280, height: 185
            type: 'text',
            x: 10, y: 205, text: 'gedruckt am {{day}}.{{month}}.{{year}}'
var print_preview = app.add(gm3.components.PrintModal, 'print-preview', {
layouts: custom_layouts
Thank you
Von: Christopher Hughes <chughes at co.lincoln.or.us>
Gesendet: Freitag, 3. März 2023 17:23
An: Anton Postl <anton.postl at zwinz.co.at>
Betreff: Re: Print Layouts
P {margin-top:0;margin-bo=tom:0;}
My assumption is that the label/orientation/page in your print template nee=s to match the format in the language json file here=/a> (or whichever language your site uses). I believe this change happened so that=eoMoose can more easily be translated into other languages.<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
So for example if you're trying to create/modify an 11x17 portrait layout t=e label would have to be tabloid-portrait, the orientation would have to b= portrait, and the page would have to be tabloid. If you're trying to =create a new template that's not in the language json files you probably would have to add them to the json fi=es and rebuild the application. You also need to make sure that you're dir=cting GeoMoose to use your custom layouts like this (I'm not sure if the w=y of doing that has change between 3.6 and 3.10):<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
var print_preview = app.add(gm3.components.PrintModal, 'print-preview', { <https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
   layouts: custom_layouts<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
If that doesn't help, sharing your print code in your app.js (including tem=lates) might help debug what's going on.<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Chris<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Chris Hughes <https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
GIS Analyst<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Lincoln County=IS Department <https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
880 NE 7th St. l Newport, OR 97365<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Tel: (541) 574=283<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Sent: Friday, March 3, 2023 12:57 AM
To: geomoose-users at lists.osgeo.org
Subject: [GeoMoose-users] Print Layouts <https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
Hello,<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
I'm trying to define my own print layout.<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
according to the instructions:<https://gi=hub.com/geomoose/gm3/blob/main/src/gm3/lang/en.json>
https://docs.geomoose.org/3.x/howto/print-layouts.html=/a><https://cas5-0-urlprotect.trendmicro.co=:443/wis/clicktime/v1/query?url=https%3a%2f%2fdocs.geomoose.org%2f3.x%2f=owto%2fprint%2dlayouts.html&umid=c51612d1-b9a3-11ed-8159-6045bd03860=&auth=dc2ed28abfc38f9dccdc580b0625a9783b471d36-3ae64ebc1903a230e5261=d8919b6b12ee162144>
in version 3.6.1 it worked without any problems. <https://cas5-0-urlprotect.trendmicro.co=:443/wis/clicktime/v1/query?url=https%3a%2f%2fdocs.geomoose.org%2f3.x%2f=owto%2fprint%2dlayouts.html&umid=c51612d1-b9a3-11ed-8159-6045bd03860=&auth=dc2ed28abfc38f9dccdc580b0625a9783b471d36-3ae64ebc1903a230e5261=d8919b6b12ee162144>
under 3.10.1 only the default layouts are displaye=, is there anything else to define?<https://cas5-0-urlprotect.trendmicro.co=:443/wis/clicktime/v1/query?url=https%3a%2f%2fdocs.geomoose.org%2f3.x%2f=owto%2fprint%2dlayouts.html&umid=c51612d1-b9a3-11ed-8159-6045bd03860=&auth=dc2ed28abfc38f9dccdc580b0625a9783b471d36-3ae64ebc1903a230e5261=d8919b6b12ee162144>
Thank you<https://cas5-0-urlprotect.trendmicro.co=:443/wis/clicktime/v1/query?url=https%3a%2f%2fdocs.geomoose.org%2f3.x%2f=owto%2fprint%2dlayouts.html&umid=c51612d1-b9a3-11ed-8159-6045bd03860=&auth=dc2ed28abfc38f9dccdc580b0625a9783b471d36-3ae64ebc1903a230e5261=d8919b6b12ee162144>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20230306/6d8da8a5/attachment-0001.htm>
More information about the GeoMoose-users mailing list
