[GeoMoose-users] Geocode search by address not working
Dara Unglaube dara at glifwc.org
Fri Sep 12 05:16:50 PDT 2025
Any ideas on how to get the API call to OSM? This worked in the past so I'm not sure what is happening. Or if there are other versions I could download the code that could help debug? Any ideas or info to get this back up and working would be greatly appreciated.
Miigwech,
Dara
Sent: Thursday, September 4, 2025 2:01 PM
To: Dara Unglaube <dara at glifwc.org>
Cc: geomoose-users at lists.osgeo.org <geomoose-users at lists.osgeo.org>
Subject: Re: [GeoMoose-users] Geocode search by address not working
On current version, I am not seeing it even get to where it does the API call to OSM.  It looks like it is failing with “mapSource is undefined”.  I’m not sure what to make of that yet.
It looks to me like the API call hasn’t changed on the OSM side so I suspect that it would still work if GeoMoose actually got that far.
On Thu, Sep 4, 2025 at 11:46 Dara Unglaube via GeoMoose-users <geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>> wrote:
Boozhoo (hello).
We are running GeoMoose 3.7.0 and the search/geocode an address stopped working awhile back. I'm trying to get it back up and working and can't seem to figure out what is wrong (request string format?). I downloaded the latest GeoMoose version's files to see if there was an update to the URL or code and all seems to be the same (mapbook.xml and geocode-osm.js). I noticed on the demo the search isn't working also. Has someone been able to get this to work or have any ideas on how to get it to work?
Thank you in advance for your time and any help you could provide. Miigwech (thank you)!
Dara
WARNING: This email was not scanned for malicious attachments or links. Please proceed carefully, and message support at glifwc.org<mailto:support at glifwc.org> with any questions.
GeoMoose-users mailing list
GeoMoose-users at lists.osgeo.org<mailto:GeoMoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
WARNING: This email was not scanned for malicious attachments or links. Please proceed carefully, and message support at glifwc.org with any questions.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20250912/5d564b86/attachment.htm>
More information about the GeoMoose-users mailing list
