[GeoMoose-users] Geocode search by address not working
Dara Unglaube
dara at glifwc.org
Fri Sep 12 10:21:09 PDT 2025
It worked! Chi-miigwech (many thanks) for your help with this. I really appreciate it.
Dara
Sent: Friday, September 12, 2025 9:29 AM
To: Dara Unglaube <dara at glifwc.org>
Cc: geomoose-users at lists.osgeo.org <geomoose-users at lists.osgeo.org>
Subject: Re: [GeoMoose-users] Geocode search by address not working
On 9/12/25 07:16, Dara Unglaube wrote:
Any ideas on how to get the API call to OSM? This worked in the past so I'm not sure what is happening. Or if there are other versions I could download the code that could help debug? Any ideas or info to get this back up and working would be greatly appreciated.
Miigwech,
Dara
Sorry, I was on vacation last week and trying to catch up this week.
After some testing this morning I am seeing:
1) The "mapSource is undefined" (also shows up as "e is undefined" in the production build) error started between v3.10.1 and v3.11.0.
2) In v3.10.1 the URL generated for the OSM API call has an extra trailing slash. It is:
https://nominatim.openstreetmap.org/search/?format=json&q=25+4th+st+west%2C+st.+paul%2C+mn
and needs to be:
https://nominatim.openstreetmap.org/search?format=json&q=25+4th+st+west%2C+st.+paul%2C+mn
This can be changed in services/geocode-osm.js on the line starting 'var osm_url ='. I suspect this change would also fix it in 3.7.0 and shouldn't require a rebuild.
3) Anything older than v3.9.0 and older won't build from git anymore due to changes in nodejs/npm.
WARNING: This email was not scanned for malicious attachments or links. Please proceed carefully, and message support at glifwc.org with any questions.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20250912/873619d5/attachment.htm>
More information about the GeoMoose-users
