[GeoMoose-users] Click value on Raster Layer
TC Haddad tchaddad at gmail.com
Wed Jan 21 11:55:10 PST 2026
Hi Dennis,
I've done exactly what you describe in GM3. Slightly different than Duck's
method because like you I serve the DEM from MapServer and in GM3 you can
still use MapServer directly as a source.
The steps are:
- create a mapfile for the DEM source, and list it as a map source in the
Mapbook
- the mapfile is configured for WMS GetInfo, STATUS is ON, and (optional)
there is no STYLE defined
- the Mapbook map source should have an identify template so that any
results are visible to the user
- user will get a result from the DEM whenever they click within the bounds
of the DEM
Here is the basic Mapbook map source if it's helpful:
<map-source name=" bare_earth " type="mapserver" tiled="false">
<file>bare_earth</file>
<layer name="bare_earth" status="on">
<template name="identify"><![CDATA[
<div class="result-item">
<div class="result-title" style="background-color: #F5DEB3; padding: 5px; ">
LiDAR Spot Elevation
</div>
<b>Bare Earth NAVD88 Elevation: </b> {{ properties.value_0 }}<br>
</div>
</template>
</layer>
<param name="FORMAT" value="image/png;bits=8"/>
</map-source>
I like having no style defined for the web service so that the DEM itself
is not visible, and the elevation result is a "bonus" result that returns
along with whatever results are relevant for the clicked location.
I haven't tried the  type="wms"  method of access for the DEM, but can set
up a test if needed. I think with status="on" in the map source you might
not need the layer to be listed in the catalog?, but without testing I'm
not sure...
best,
Tanya
On Wed, Jan 21, 2026 at 9:13 AM Dan Little via GeoMoose-users <
geomoose-users at lists.osgeo.org> wrote:
> Hi Dennis!
> Sorry for the slow response here. In the history of GM3, I could not find
> any other queries about raster investigation! A total valid use case,
> especially for identify!
> GeoMoose3 works differently with WMS/WFS being the primary way it tries to
> process results. GeoMoose 2 allowed raw HTML insertion from MapServer and
> that workflow was getting increasingly frowned upon for security reasons.
> Is there any chance there is a public endpoint for this right now? It
> looks like the basic process should be:
> - Configure the DEM as WMS (looks like that's done)
> - Defined the <map-source type="wms"> in the mapbook with a <layer> with a
> <template> for identify
> - (This may be the controversial part) You'll need a <catalog> <layer />
> </catalog> entry that lets the layer be on. This might be avoided with some
> tricks but I haven't dug all the way in yet. If anything this might be a
> necessary debugging step to ensure the WMS is reprojecting properly.
> All together this would look something like this:
>     <map-source name="dem" type="wms">
>         <url>http://somewhere.over/the/rainbow/wms?</url>
>         <layer name="DEM" status="on">
>                 <div class="identify-result">
>                 <div class="item"><label>Elevation:</label>{{
> properties.item name=value_0|fix>1 }}</div>
>                 </div>
>             ]]></template>
>         </layer>
>         <param name="FORMAT" value="image/png"/>
>         <param name="TRANSPARENT" value="TRUE"/>
>         <param name="cross-origin" value="anonymous"/>
>     </map-source>
> <catalog>
>   <layer src="dem/dem" title="DEM" />
> </catalog>
> On Mon, Jan 19, 2026 at 11:51 AM Dennis Falkenberg via GeoMoose-users <
>> I am working on a new GM3 site and would like to replicate, if possible,
>> something available on our current GM2.6 site.
>> The GeoMoose sites are located on an AWS EC2 server.  With our GM2.6
>> site, any location that was clicked with the identify tool returned an
>> elevation value based on our most current DEM.  The DEM was listed in the
>> map source portion of the conf file, but not in the catalog in GM2.6.
>> Is it possible to capture elevations off of a DEM with GM3?  My map file
>> configuration and identify html verbiage are just below.
>> Any help would be appreciated!  Thank you
>> LAYER # DEM_20
>>                                 NAME 'be_dem_20'
>>                                 STATUS ON
>>                                 TYPE RASTER
>>                                 DATA 'data/dem/2020/ChippewaCo_DEM.tif'
>>                                 CLASSITEM "[pixel]"
>>                                 OFFSITE 0 0 0
>>                                 MAXSCALEDENOM 25
>>                                 PROJECTION
>>                                                 'init=epsg:7595'
>>                                 END
>>                                 METADATA
>>                                                 'ows_title' 'be_dem_20'
>>                                                 'ows_include_items' 'all'
>>                                                 'gml_include_items' 'all'
>>                                                 'ows_exclude_items'
>> 'SHAPE_area,SHAPE_len'
>>                                                 'gml_exclude_items'
>>                                 END
>>                                 TOLERANCEUNITS meters
>>                                 TOLERANCE 0
>> #                             CLASS
>> #                                             STYLE
>> #                                                             COLORRANGE
>> 255 255 255 0 0 0
>> #                                                             DATARANGE
>> 874 1201
>> #                                             END
>> #                             END
>>                                 TEMPLATE 'dummy'
>>                 END # DEM_20
>>     <div class="feature-class">2020 Elevation</div>
>> </div>
>> *Dennis Falkenberg*
>> Chippewa County GIS Coordinator
>> 715.738.2595
>> dfalkenberg at chippewacountywi.gov <dfalkenberg at co.chippewa.wi.us>
>> Desktop Mapping Site <https://mapping.chippewacountywi.gov/>
>> Mobile Friendly Mapping Site
>> <https://chipcogis.maps.arcgis.com/apps/webappviewer/index.html?id=258d5a3b2ee2476bb1953a443cd703c8>
>> Data upload site
>> <https://chippewacounty.sharefile.com/filedrop/dxa8988a-58cf-4413-b8be-ac4ce8428204>
>> CHIPPEWA COUNTY COURTHOUSE HOURS
>> MONDAY-THURSDAY 7:30 – 4:30
>> FRIDAY 7:30-11:30
>> GeoMoose-users mailing list
>> GeoMoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20260121/dc87c3f8/attachment-0001.htm>
More information about the GeoMoose-users mailing list
