[GeoMoose-users] Results Templates - Format Dates
Dan Little
theduckylittle at gmail.com
Wed Oct 7 13:53:41 PDT 2026
While not a totally perfect solution, Javascript's lack of types can be
kinda valuable here:
function normalizeDate(value) {
const d = new Date(value); // this will do a best guess
return (new Intl.DateTimeFormat().format(d)); // this will use the user's
locale to format the date
That could be used in a pipe to format arbitrary date values. A little
duck-typing/data checking could make it a lot safer.
On Wed, Oct 7, 2026 at 12:56 PM Christopher Hughes via GeoMoose-users <
geomoose-users at lists.osgeo.org> wrote:
> Hello everyone,
> I was curious if anyone has had success altering date formats specifically
> in GeoMoose's template results. I've had some success adjusting the results
> using the pipes found at adammark/Markup.js: Powerful JavaScript templates
> <https://github.com/adammark/Markup.js/> (i.e. converting results to
> uppercase/lowercase, adjusting the default null value, replacing one string
> with another). It does give some examples of how to format dates, but I
> wasn't sure how to implement that in GeoMoose's deployment of MarkUp.
> The issue is I'm trying to connect to a rest service (so I don't have
> control of the data at the source). It has a few fields that come through
> as YYYY-MM-DDTHH:MM:SS-[whatever the UTC modifier is] (which works but is a
> bit ugly), and a couple that come through as the number of seconds since
> 1970 (which is less useful for the average person).
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County GIS Department
> 880 NE 7th St
> <https://www.google.com/maps/search/880+NE+7th+St?entry=gmail&source=g>.
> l Newport, OR 97365
> Tel: (541) 574 1283 <(541)%20574-1283>
> GeoMoose-users mailing list
> GeoMoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20261007/8bd4e541/attachment.htm>
More information about the GeoMoose-users
