[GeoNode-devel] How to add boundless geoserver-exts to the maven repo?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Dec 2 09:11:23 PST 2015
GeoNode needs the geogig extension for GeoServer which seems to be
misaligned from the one present in geoserver-exts.
I suspect GeoNode is using an outdated version of GeoGig extension and in
any case it would be useful having the artifacts on the maven repo in order
to keep the GeoNode-GeoServer Extension always in sync with the GeoServer
versions.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Wed, Dec 2, 2015 at 6:08 PM, Jody Garnett <jody.garnett at gmail.com> wrote:
> Which module? That repo has a few small extensions for OpenGeo Suite -
> many of which are now geoserver community modules.
> On Wed, Dec 2, 2015 at 6:50 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi all,
>> can someone add the https://github.com/boundlessgeo/geoserver-exts
>> artifacts to the boundless maven repo?
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
> Jody Garnett
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151202/283d6c2f/attachment.html>
More information about the geonode-devel
