[GeoNode-devel] GeoServer 2.7.x integration
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jul 6 08:21:28 PDT 2015
sure, thanks Alessio!
2015-07-06 17:18 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> Alessio, You should be able to just modify this job now.
> http://52.5.141.226/job/geoserver-geonode-dev/ ... the old build
> server seems to be completely broken, so I cant look at the setup
> there, but it should be a straightforward mvn jenkins job. Let us know
> if you run into any trouble.
> Simone and Ariel, can you guys help get the geoserver and
> geonode-geoserver launchpad packages working with this new version as
> well. We should try to get to a snapshots package that includes this
> 2.7 geoserver ASAP so we can do some testing in the next weeks before
> releasing.
> On Mon, Jul 6, 2015 at 8:14 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Yes please, I never did it.
> > I'll check the server though and take a look at the other jobs.
> > Thanks,
> > Alessio.
> > P.S.: I updated the pom in order to automatically build the WAR into the
> > target folder also, but if it is not needed we can remove it.
> > GeoServer Professional Services from the experts! Visit
> > http://goo.gl/NWWaa2 for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via Poggio alle Viti 1187
> > 55054 Massarosa (LU)
> > Italy
> > phone: +39 0584 962313
> > fax: +39 0584 1660272
> > mob: +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> > finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> > cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> > information in this message that has been received in error. The sender
> does
> > not give any warranty or accept liability as the content, accuracy or
> > completeness of sent messages and accepts no responsibility for changes
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > On Mon, Jul 6, 2015 at 5:11 PM, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
> >> Alessio,
> >> Thanks for this!
> >> Can I get you setup on the jenkins server to setup the job there to
> >> build this and produce the war? I haven't done any work on configuring
> >> that job since migrating off of the older build server. I've added
> >> your GH username as an admin in this jenkins. You may need ssh access
> >> in order to put the artifact in the right place on the filesystem so
> >> we can update the packages and pavement script.
> >> http://52.5.141.226/ (old one is here http://build.geonode.org:8088/,
> >> still need to migrate the DNS)
> >> Jeff
> >> On Mon, Jul 6, 2015 at 8:04 AM, Alessio Fabiani
> >> > Dear all,
> >> > I had the chance to work on the integration of GeoServer 2.7.x with
> >> > GeoNode
> >> > master. Currently I updated the geoserver-geonode-ext code in order to
> >> > build
> >> > automatically the GeoServer WAR with the updated GS DATA DIR and the
> >> > integrated secutiry module.
> >> > All the test-cases pass and also I tested with a running version of
> >> > GeoNode.
> >> > I guess there could be some issues with the GeoTIFF uploading when
> using
> >> > the
> >> > Importer, but I'm still verifying.
> >> > Here is the integration of GeoServer 2.7.x with GeoNode master.
> >> > https://github.com/geosolutions-it/geoserver-geonode-ext/tree/2.7.x
> >> > Have you the chance to test it and report any issue?
> >> > Regards,
> >> > Alessio.
> >> > @alfa7691
> >> > GeoSolutions S.A.S.
> >> > Italy
> >> > nel/i
> per
> >> > le
> >> > messaggio
> >> > notizia
> >> > divulgarlo
> utilizzarlo
> >> > per
> >> > dettati
> >> > for
> confidential
> >> > or
> Protection
> >> > reproduction,
> partial,
> >> > is
> sender
> >> > does
> changes
> of
> >> > _______________________________________________
> >> > geonode-devel mailing list
> >> > geonode-devel at lists.osgeo.org
> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150706/abd9d726/attachment-0001.html>
More information about the geonode-devel
