[GeoNode-devel] new geoserver build server
Jeffrey Johnson ortelius at gmail.com
Tue Jul 7 16:55:58 PDT 2015
The DNS has propagated. demo.geonode.org and build.geonode.org both
answer. I fixed the callback url and some of you should be able to
login to jenkins now with your github account.
Simone, lets fix up the demo job tomorrow and make sure its all running.
On Tue, Jul 7, 2015 at 2:59 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> I just migrated the DNS, amazon weirdly recycled the elastic IP
> address (or more likely my mistake), so for me demo.geonode.org is
> pointing to the build server for now.
> They should resolve this way shortly.
> build 52.7.139.177
> demo 54.173.247.36
> On Tue, Jul 7, 2015 at 8:45 AM, Ariel Nunez <ingenieroariel at gmail.com> wrote:
>> Ciao Simone,
>> In the past:
>>  - When we had trouble reporting bugs upstream geoserver it was best to be
>> able to point at a stable version.
>>  - If we wanted to switch the pom.xml to a point release, there were a lot
>> of missing artifacts making snapshots the only solution (to be able to
>> release against point releases we had to bug Justin to add missing jars to
>> the maven repo),
>>  - If people wanted to add other GeoServer plugins they could get them from
>> GeoServer's build service.
>> However, I agree with your suggestion to move master to 2.7-SNAPSHOT and can
>> deal with the above once we release final.
>> -a
>> On Tue, Jul 7, 2015 at 10:26 AM, Alessio Fabiani
>> <alessio.fabiani at geo-solutions.it> wrote:
>>> Ariel,
>>> just pushed in the merge of the conflicts.
>>> -A.
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/NWWaa2 for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via Poggio alle Viti 1187
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>>> finalità diverse, costituisce comportamento contrario ai principi dettati
>>> dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely for
>>> the attention and use of the named addressee(s) and may be confidential or
>>> proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender does
>>> not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Tue, Jul 7, 2015 at 5:24 PM, Simone Giannecchini
>>> <simone.giannecchini at geo-solutions.it> wrote:
>>>> Ciao Ariel,
>>>> quick thoughts, are we user we _don't_ want GeoNode master to lean
>>>> onto GeoServer 2.7.x?
>>>> I agree we should not have GeoNode Master depend on an unstable
>>>> GeoServer but 2.7.x is already hence it is getting fixes and small new
>>>> features.
>>>> Using nightlies would ensure that whenever a fix is needed in
>>>> GeoServer to move with GeoNode we get it right away rather than having
>>>> to wait 1 or 2 months and coming up with a workaround.
>>>> I might want to move back to fixed version once we talk about stable
>>>> GeoNode, although even at that point we might want to leverage on the
>>>> nightly for the maintenance branch of GeoServer so that we get bugixes
>>>> right away.
>>>> I believe that a strong link between GeoNode and GS is key for the
>>>> success of the first one (or both :) ).
>>>> Looking forward to reading your (and the others' feedback).
>>>> Regards,
>>>> Simone Giannecchini
>>>> PS
>>>> Apologize for pushing this quickly but we have a project with a
>>>> limited time window where we want to really push this through for
>>>> longer term maintainability.
>>>> We are more than happy to comply with what the community decides on this.
>>>> Visit http://goo.gl/it488V for more information.
>>>> Ing. Simone Giannecchini
>>>> @simogeo
>>>> Founder/Director
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> mob:   +39 333 8128928
>>>> Il loro utilizzo è consentito esclusivamente al destinatario del
>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora
>>>> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
>>>> cortesemente di darcene notizia via e-mail e di procedere alla
>>>> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
>>>> Conservare il messaggio stesso, divulgarlo anche in parte,
>>>> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
>>>> diverse, costituisce comportamento contrario ai principi dettati dal
>>>> D.Lgs. 196/2003.
>>>> for the attention and use of the named addressee(s) and may be
>>>> confidential or proprietary in nature or covered by the provisions of
>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
>>>> Data Protection Code).Any use not in accord with its purpose, any
>>>> disclosure, reproduction, copying, distribution, or either
>>>> dissemination, either whole or partial, is strictly forbidden except
>>>> previous formal approval of the named addressee(s). If you are not the
>>>> intended recipient, please contact immediately the sender by
>>>> telephone, fax or e-mail and delete the information in this message
>>>> that has been received in error. The sender does not give any warranty
>>>> or accept liability as the content, accuracy or completeness of sent
>>>> messages and accepts no responsibility  for changes made after they
>>>> were sent or for other risks which arise as a result of e-mail
>>>> On Tue, Jul 7, 2015 at 4:59 PM, Ariel Nunez <ingenieroariel at gmail.com>
>>>> wrote:
>>>> > Alessio,
>>>> > I see you pegging it to 2.7-SNAPSHOT, is it possible to peg it to an
>>>> > specific geoserver version?
>>>> > Also, I saw there were merging issues against master in that PR, could
>>>> > you
>>>> > help resolve those before we can pull?
>>>> > -a
>>>> > On Tue, Jul 7, 2015 at 9:37 AM, Alessio Fabiani
>>>> >> Hi all,
>>>> >> the pull request for merging the geonode-geoserver-ext improvements is
>>>> >> here
>>>> >> https://github.com/GeoNode/geoserver-geonode-ext/pull/37
>>>> >> while we still having a known issue when using the GeoServer Importer
>>>> >> mechanism for the upload of the GeoTIFFs which has been reported here
>>>> >> https://github.com/GeoNode/geonode/issues/2216
>>>> >> Regards,
>>>> >> Alessio Fabiani.
>>>> >> @alfa7691
>>>> >> GeoSolutions S.A.S.
>>>> >> Italy
>>>> >> Il loro
>>>> >> per le
>>>> >> messaggio
>>>> >> notizia
>>>> >> divulgarlo
>>>> >> utilizzarlo per
>>>> >> dettati
>>>> >> for
>>>> >> confidential or
>>>> >> Protection
>>>> >> reproduction,
>>>> >> partial, is
>>>> >> sender does
>>>> >> changes
>>>> >> of
>>>> >> On Tue, Jul 7, 2015 at 4:28 PM, Jeffrey Johnson <ortelius at gmail.com>
>>>> >> wrote:
>>>> >>> Nice to see this building again!
>>>> >>> http://52.5.141.226/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/
>>>> >>> On Tue, Jul 7, 2015 at 7:27 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>> >>> wrote:
>>>> >>> > +1
>>>> >>> > Thanks Alessio!
>>>> >>> > On Tue, Jul 7, 2015 at 7:26 AM, Ariel Nunez
>>>> >>> > wrote:
>>>> >>> >> +1
>>>> >>> >> On Tue, Jul 7, 2015 at 9:19 AM, Paolo Pasquali
>>>> >>> >> <paolo.pasquali at ithaca.polito.it> wrote:
>>>> >>> >>> +1
>>>> >>> >>> No complains.
>>>> >>> >>> Thank you Alessio!
>>>> >>> >>> On Tue, Jul 7, 2015 at 4:16 PM, Simone Dalmasso
>>>> >>> >>> <simone.dalmasso at gmail.com> wrote:
>>>> >>> >>>> Hi devs,
>>>> >>> >>>> thanks to @afabiani we have a new geoserver build server and
>>>> >>> >>>> also
>>>> >>> >>>> bump
>>>> >>> >>>> it's version to 2.7.
>>>> >>> >>>> We would like to migrate the DNS to this new one then. If there
>>>> >>> >>>> are
>>>> >>> >>>> no
>>>> >>> >>>> complains from the community we will proceed in the next days.
>>>> >>> >>>> the new geoserver will be available at
>>>> >>> >>>> http://build.geonode.org/geoserver/latest/geoserver.war as
>>>> >>> >>>> before
>>>> >>> >>>> Note that this will only affect new installations in dev mode
>>>> >>> >>>> for
>>>> >>> >>>> now,
>>>> >>> >>>> not the installations made via apt-get.
>>>> >>> >>>> The GeoNode dev team
>>>> >>> >>>> _______________________________________________
>>>> >>> >>>> geonode-devel mailing list
>>>> >>> >>>> geonode-devel at lists.osgeo.org
>>>> >>> >>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
