[GeoNode-devel] geoserver-geonode-ext - geonode_authorize_layer.sql modification
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 14 08:42:45 PDT 2015
+1
2015-07-14 16:49 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> This seems reasonable to me, but havent tested it. Anyone have any
> concerns or objections to merging it?
> On Mon, Jul 13, 2015 at 11:13 AM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
>> I would like to propose the pull request be added to the geoserver-geonode-ext master.
>> https://github.com/GeoNode/geoserver-geonode-ext/pull/41
>> The geonode_authorize_layer.sql does not work correctly for group authentication.
>> When creating a new group an entry is added to the "auth_group" table with the first row automatically created for the anonymous group
>> auth_group
>> id [PK] serial, name character varying(80)
>> 1,anonymous
>> The geonode_authorize_layer function creates the group_ids (integer[]) by querying the "groups_groupmember"."group_id" column.
>> The issue is that the group_id column does not account for the anonymous group. So when GeoServer is running the prepared statement. The result is actually "groups_groupmember"."group_id" -1. A quick fix is just to add 1 to each value in the "group_ids", since the anonymous group will always be the first entry.
>> I replaced the following in geonode_authorize_layer.sql
>> SELECT INTO group_ids array_agg("groups_groupmember"."group_id" + 1)
>>   FROM "groups_groupmember"
>>   WHERE "groups_groupmember"."user_id" = "user".id;
>> with the following:
>> *Daniel Berry*
>> Professional Services Engineer | Boundless
>> 512-468-3946 (cell)
>> @boundlessgeo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150714/0509d9bd/attachment-0001.html>
More information about the geonode-devel mailing list
