[GeoNode-devel] Fwd: automatic authentication/login from geonode to geoserver does not work
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jul 16 04:11:58 PDT 2015
Forwarding to the osgeo mailing list. Remember to consider the opengeo one
as dismissed
---------- Forwarded message ----------
Date: 2015-07-16 12:47 GMT+02:00
Subject: Re: automatic authentication/login from geonode to geoserver does
not work
To: geonode-dev at opengeo.org
Cc: chrisy.wolf at gmail.com
Hi Devs,
I'm facing this same problem but with the latest GeoNode 2.4 beta and
GeoServer 2.7.
I made a custom installation in a virtualenv with both GeoNode and
GeoServer responding on port 80.
So I'm getting this error:
Error connecting to the GeoNode server for authentication purposes
GeoNode communication failed, status report is: 404, Not Found,
http://localhost/layers/acls
I played with the settings but without success.
Thanks in advanced for your help.
Bye
Paolo
On Wednesday, January 7, 2015 at 11:14:34 AM UTC+1, chris... at gmail.com
wrote:
> Hello,
> maybe somebody can help me.
> i have following problem:
> Geoserver application can not find geonode application on same server to
> authentificate and automatic login to geoserver with same credentials. I
> must login on geoserver app again. Also layer on geonode will not display
> because automatic login to geoserver app does not work.
> geoserver.log say:
> 2015-01-07 10:32:06,039 WARN [geonode.security] - Error connecting to the
> org.springframework.security.authentication.AuthenticationServiceException:
> Communication with GeoNode failed
>         at
> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>         at
> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>         at
> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>         at
> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>         at
> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>         at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>         at
> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>         at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>         at
> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>         at
> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>         at
>         at
> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>         at
>         at
>         at
> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>         at
> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>         at
>         at
>         at
>         at
> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>         at
> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>         at
> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>         at
> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>         at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>         at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>         at
> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>         at
>         at
>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>         at
>         at
>         at
> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>         at
>         at
>         at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>         at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>         at
> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>         at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>         at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>         at
> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>         at
> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>         at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>         at
> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
>         at
> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>         at
> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>         at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>         at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>         at java.lang.Thread.run(Thread.java:745)
> Caused by: java.io.IOException: GeoNode communication failed, status
> report is: 404, Not Found, http://localhost:8080/layers/acls
>         at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:72)
>         at
> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>         at
> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>         at
> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>         ... 47 more
> i have checked
> /opt/geonode/geoserver/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> /var/lib/tomcat7/webapps/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> and set baseUrl to http://localhost and also http://localhost:8080 but
> both does not work.
> Apache listen on Port 80
> tcp        0      0 0.0.0.0:80              0.0.0.0:*
> LISTEN      0          5099632     15956/apache2
> Apache geonode.conf:
> WSGIDaemonProcess geonode user=www-data threads=15 processes=2
> <VirtualHost *:80>
>     Servername localhost
>     ServerAdmin webmaster at localhost
>     ErrorLog /var/log/apache2/error.log
>     LogLevel warn
>     CustomLog /var/log/apache2/access.log combined
>     WSGIProcessGroup geonode
>     WSGIPassAuthorization On
>     WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>     <Directory "/var/www/geonode/">
>        Order allow,deny
>         Options Indexes FollowSymLinks
>         Allow from all
>         IndexOptions FancyIndexing
>     </Directory>
>     Alias /static/ /var/www/geonode/static/
>     Alias /uploaded/ /var/www/geonode/uploaded/
>     Alias /robots.txt /var/www/geonode/robots.txt
>     <Directory "/var/www/geonode/uploaded/documents/">
>        Order allow,deny
>        Deny from all
>     </Directory>
>     <Proxy *>
>       Order allow,deny
>       Allow from all
>     </Proxy>
>     ProxyPreserveHost On
>     ProxyPass /geoserver http://localhost:8080/geoserver
>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
> </VirtualHost>
> My environment:
> Ubuntu 14.04.1 LTS
> Geoserver 2.5.1
> Geonode 2.4dev
> Do you need more informations?
> Thanks for help
> Best regards
> Christian
 To unsubscribe from this group and stop receiving emails from it, send an
email to geonode-dev+unsubscribe at opengeo.org.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150716/0d070623/attachment-0001.html>
More information about the geonode-devel mailing list
