[GeoNode-devel] Which GeoServer version we should use (i.e. nightlies VS releases)
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 31 12:07:28 PDT 2015
+1 very flexible.
Il venerdì 31 luglio 2015, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> This makes sense. +1
> On Friday, July 31, 2015, Simone Giannecchini <
> simone.giannecchini at geo-solutions.it
> <javascript:_e(%7B%7D,'cvml','simone.giannecchini at geo-solutions.it');>>
> wrote:
>> Dear All,
>> recently I have been discussing with other devs about which GS version
>> we should depend onto in GeoNode.
>> As you might know GeoServer has, at all times, 3 active branches:
>> - Master (2.8.x at this stage) which is open for development and is
>> considered unstable
>> - Stable (2.7.x now) which get minor developments + bug fixes
>> - Maintenance (2.6.x now) which gets only bug fixes
>> GS has a time-boxed release model so we more or less know when a
>> release for a certain branch will be made.
>> Generally speaking (at least IMHO) for a project like GN it is good to
>> depend on the stable branch. Master would be dangerous, Maintenance
>> could be moving too slow (but still an option).
>> So yeah, that's fine we are already doing that. The point is what to
>> do when we cut a GN release? Do we use a GS nightly ( they are all
>> marked clearly and then we can track it easily)? Do we only use
>> releases?
>> The obvious answer is to use releases from the stable branch and make
>> everybody happy. There is one problem though unless we align with the
>> GS releases we might have problem with doing GS bugfixes before a GN
>> release.
>> Let's talk about present times. Right now we are depending on 2.7.x
>> nightly, so if there's something bugging us in GS we fix it and the
>> day after we get the fix in GN. If on September 1st we want to release
>> GN 2.4 we won't have a GS release to use because 2.7.3 will be out in
>> October, hence we either wait or we ask the GeoServer community to
>> make an intermediate release (e.g. 2.7.2.1).
>> My proposal is as follows:
>> - try to track geoserver stable nightly in GN development
>> - tentatively align GN release to GS releases (they are done pretty
>> often anyway)
>> - if we want to do a GN release and we can't wait for a GS one, we ask
>> the GS community to cut an intermediate release
>> Feedback?
>> PS
>> I already started a similar discussion on the GS mailing asking for
>> opinions on this approach :)
>> Regards,
>> Simone Giannecchini
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Simone Giannecchini
>> @simogeo
>> Founder/Director
>> GeoSolutions S.A.S.
>> Via Poggio alle Viti 1187
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  333 8128928
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
>> Il loro utilizzo è consentito esclusivamente al destinatario del
>> messaggio, per le finalità indicate nel messaggio stesso. Qualora
>> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
>> cortesemente di darcene notizia via e-mail e di procedere alla
>> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
>> Conservare il messaggio stesso, divulgarlo anche in parte,
>> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
>> diverse, costituisce comportamento contrario ai principi dettati dal
>> D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be
>> confidential or proprietary in nature or covered by the provisions of
>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
>> Data Protection Code).Any use not in accord with its purpose, any
>> disclosure, reproduction, copying, distribution, or either
>> dissemination, either whole or partial, is strictly forbidden except
>> previous formal approval of the named addressee(s). If you are not the
>> intended recipient, please contact immediately the sender by
>> telephone, fax or e-mail and delete the information in this message
>> that has been received in error. The sender does not give any warranty
>> or accept liability as the content, accuracy or completeness of sent
>> messages and accepts no responsibility  for changes made after they
>> were sent or for other risks which arise as a result of e-mail
>> transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150731/85f54521/attachment.html>
More information about the geonode-devel mailing list
