[GeoNode-devel] GeoNode 2.4 status
    Francesco Bartoli
    xbartolone at gmail.com
    Thu Jun 25 06:59:27 PDT 2015
just a quick update. I find out the reason of failure:
Class GeoserverDataDirectory [1] is no longer present in the package org.vfny.geoserver.global [2] and should be replaced by GeoServerResourceLoader [3]
I’ll try to rebuild as soon as I can with this modifications
Francesco
[1] https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java#L85
[2] https://github.com/geoserver/geoserver/tree/2.7.x/src/main/src/main/java/org/vfny/geoserver/global
[3] https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/GeoServerDataDirectory.java#L64
Il giorno 25/giu/2015, alle ore 02:42, Francesco Bartoli <xbartolone at gmail.com> ha scritto:
> Hi Paolo,
> I have tried to upgrade geoserver-geonode-ext with alignment to the latest stable 2.7.1. After minor issues in dependencies the build fails at this point:
> [ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project geonode-geoserver-ext: Compilation failure: Compilation failure:
> [ERROR] /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[18,33] cannot find symbol
> [ERROR] symbol:   class GeoserverDataDirectory
> [ERROR] location: package org.vfny.geoserver.global
> [ERROR] /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[85,44] cannot find symbol
> [ERROR] symbol:   variable GeoserverDataDirectory
> [ERROR] location: class org.geonode.security.GeoNodeSecurityProvider
> [ERROR] -> [Help 1]
> org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project geonode-geoserver-ext: Compilation failure
> 	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
> 	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
> 	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
> 	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
> 	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
> 	at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
> 	at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
> 	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
> 	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
> 	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
> 	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
> 	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
> 	at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
> 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> 	at java.lang.reflect.Method.invoke(Method.java:606)
> 	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
> 	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
> 	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
> 	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
> Caused by: org.apache.maven.plugin.compiler.CompilationFailureException: Compilation failure
> 	at org.apache.maven.plugin.compiler.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:858)
> 	at org.apache.maven.plugin.compiler.CompilerMojo.execute(CompilerMojo.java:129)
> 	at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
> 	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
> 	... 20 more
> [ERROR]
> [ERROR] Re-run Maven using the -X switch to enable full debug logging.
> [ERROR]
> [ERROR] For more information about the errors and possible solutions, please read the following articles:
> [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
> Tomorrow I don’t have time to investigating more but if somebody can take a look then I can retry the build. Anyway attached there is the POM used to build
> Cheers,
> Francesco
> <pom.xml>
> Il giorno 24/giu/2015, alle ore 15:47, Paolo Corti <pcorti at gmail.com> ha scritto:
>> Hi Simone
>>> There are also a couple of other things that can be addressed before the
>>> release if they are fixed in time otherwise will go to 2.4.1:
>>> - notifications rework
>>> - better cache management and invalidation for thumbnails and tiles
>>> - Geoserver upgrade to 2.7
>> We should upgrade asap GeoServer as this recently discovered important
>> security vulnerability has been fixed only for 2.6.4 and 2.7.2 (we
>> should consider to repackage GeoServer for stable 2.0 imho):
>> https://osgeo-org.atlassian.net/browse/GEOS-7032
>> For the rest, migrations script [1] worked well for us (WFP), we are
>> extensively testing it and will go in production with 2.4 by the end
>> of the month.
>> Another think I would love to see in 2.4 is the gxp classify tool,
>> almost done by Matt I believe [2]
>> cheers
>> p
>> [1] https://github.com/capooti/geonode/tree/migration_from20_to_24
>> [2] https://github.com/boundlessgeo/gxp/pull/231/files#r31339623
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150625/88e86326/attachment-0001.html>
More information about the geonode-devel
