[GeoNode-devel] GeoNode 2.4 status
Francesco Bartoli
xbartolone at gmail.com
Thu Jun 25 09:05:24 PDT 2015
Jeffrey,
are you referring to this repo https://github.com/GeoNode/geonode.github.com ?
F.
Il giorno 25/giu/2015, alle ore 17:37, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> Francesco (or anyone else), I wonder if you can send a Pull request
> against the website to add to the gallery here
> http://geonode.org/gallery/
> On Thu, Jun 25, 2015 at 8:12 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>> Ciao Ariel,
>> yes I am :). I’m going to launch SDI for snow avalanche information
>> (http://geoavalanche.org) on top of GeoNode
>> F.
>> Il giorno 25/giu/2015, alle ore 17:00, Ariel Nunez
>> <ingenieroariel at gmail.com> ha scritto:
>> Ciao Francesco,
>> Thanks for looking into this, are you the same Francesco that is behind
>> GeoBeyond? I have seen some of your writing when reading about open source
>> geo in italy.
>> Buon hacking,
>> -a
>> On Thu, Jun 25, 2015 at 8:59 AM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi,
>>> just a quick update. I find out the reason of failure:
>>> Class GeoserverDataDirectory [1] is no longer present in the package
>>> org.vfny.geoserver.global [2] and should be replaced by
>>> GeoServerResourceLoader [3]
>>> I’ll try to rebuild as soon as I can with this modifications
>>> Francesco
>>> [1]
>>> https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java#L85
>>> [2]
>>> https://github.com/geoserver/geoserver/tree/2.7.x/src/main/src/main/java/org/vfny/geoserver/global
>>> [3]
>>> https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/GeoServerDataDirectory.java#L64
>>> Il giorno 25/giu/2015, alle ore 02:42, Francesco Bartoli
>>> <xbartolone at gmail.com> ha scritto:
>>> Hi Paolo,
>>> I have tried to upgrade geoserver-geonode-ext with alignment to the latest
>>> stable 2.7.1. After minor issues in dependencies the build fails at this
>>> point:
>>> [ERROR] Failed to execute goal
>>> org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile)
>>> on project geonode-geoserver-ext: Compilation failure: Compilation failure:
>>> [ERROR]
>>> /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[18,33]
>>> cannot find symbol
>>> [ERROR] symbol: class GeoserverDataDirectory
>>> [ERROR] location: package org.vfny.geoserver.global
>>> [ERROR]
>>> /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[85,44]
>>> cannot find symbol
>>> [ERROR] symbol: variable GeoserverDataDirectory
>>> [ERROR] location: class org.geonode.security.GeoNodeSecurityProvider
>>> [ERROR] -> [Help 1]
>>> org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute
>>> goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile
>>> (default-compile) on project geonode-geoserver-ext: Compilation failure
>>> at
>>> org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
>>> at
>>> org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
>>> at
>>> org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
>>> at
>>> org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
>>> at
>>> org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
>>> at
>>> org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
>>> at
>>> org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
>>> at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
>>> at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
>>> at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
>>> at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
>>> at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
>>> at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> at
>>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
>>> at
>>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
>>> at java.lang.reflect.Method.invoke(Method.java:606)
>>> at
>>> org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
>>> at
>>> org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
>>> at
>>> org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
>>> at
>>> org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
>>> Caused by: org.apache.maven.plugin.compiler.CompilationFailureException:
>>> Compilation failure
>>> at
>>> org.apache.maven.plugin.compiler.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:858)
>>> at
>>> org.apache.maven.plugin.compiler.CompilerMojo.execute(CompilerMojo.java:129)
>>> at
>>> org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
>>> at
>>> org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
>>> ... 20 more
>>> [ERROR]
>>> [ERROR] Re-run Maven using the -X switch to enable full debug logging.
>>> [ERROR]
>>> [ERROR] For more information about the errors and possible solutions,
>>> please read the following articles:
>>> [ERROR] [Help 1]
>>> http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
>>> Tomorrow I don’t have time to investigating more but if somebody can take
>>> a look then I can retry the build. Anyway attached there is the POM used to
>>> build
>>> Cheers,
>>> Francesco
>>> <pom.xml>
>>> Il giorno 24/giu/2015, alle ore 15:47, Paolo Corti <pcorti at gmail.com> ha
>>> scritto:
>>> Hi Simone
>>> There are also a couple of other things that can be addressed before the
>>> release if they are fixed in time otherwise will go to 2.4.1:
>>> - notifications rework
>>> - better cache management and invalidation for thumbnails and tiles
>>> - Geoserver upgrade to 2.7
>>> We should upgrade asap GeoServer as this recently discovered important
>>> security vulnerability has been fixed only for 2.6.4 and 2.7.2 (we
>>> should consider to repackage GeoServer for stable 2.0 imho):
>>> https://osgeo-org.atlassian.net/browse/GEOS-7032
>>> For the rest, migrations script [1] worked well for us (WFP), we are
>>> extensively testing it and will go in production with 2.4 by the end
>>> of the month.
>>> Another think I would love to see in 2.4 is the gxp classify tool,
>>> almost done by Matt I believe [2]
>>> cheers
>>> p
>>> [1] https://github.com/capooti/geonode/tree/migration_from20_to_24
>>> [2] https://github.com/boundlessgeo/gxp/pull/231/files#r31339623
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150625/6c63643f/attachment.html>
More information about the geonode-devel
