[GeoNode-devel] groups permissions in 2.4
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 5 01:57:35 PDT 2015
Rainer,
I can't replicate the behavior, I create a group in the group tab and then
it's available in the autocomplete. The function that is handling that is
this one https://github.com/GeoNode/geonode/blob/master/geonode/views.py#L70
and
it simply does a GroupProfile.objects.filter.
Can you try to run these commands:
$ geonode shell
>>> from geonode.groups.models import GroupProfile
>>> GroupProfile.objects.all()
and see whether it's correctly returning your groups.
2015-05-05 10:26 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> Hi Simone,
> I installed 2.4.0+beta25 from the testing ppa and still I cant get any
> results from the groups autocomplete field. The response for the ajax
> request is {"count": 0, "users": [], "groups": []}
> I added an '*' to the  the ALLOWED_HOSTS in local_settings.py, if thats of
> any importance for above problem.
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-04 14:31 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> super thanks! I'll just use a fresh vagrant vm
>> 12053 Berlin
>> Germany / Allemagne
>> 2015-05-04 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Yes will overwrite the current one. I suggest you to use a new Ubuntu
>>> though. Because until we release the final the upgrade between versions may
>>> not be smooth.
>>> Il lunedì 4 maggio 2015, Rainer Lissewski <r.lissewski at aplikate.eu> ha
>>> scritto:
>>>> oh wow! will this be available via ppa directly?
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> 2015-05-04 13:35 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> weird, anyway I'm going to release e new beta today, you can install
>>>>> it and should solve. If you install it within 4 hours you'll get a faster
>>>>> and better geonode.
>>>>> 2015-05-04 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>>> exactly, the autocomplete isnt working
>>>>>> 12053 Berlin
>>>>>> Germany / Allemagne
>>>>>> 2015-05-04 13:29 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> On my 2.4 after I create a group in the groups section then it will
>>>>>>> appear in the autocomplete. Is it not working for you?
>>>>>>> 2015-05-04 13:25 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu
>>>>>>>> Ok I installed on trusty 14.04 and it is  2.4.0+beta24 (just
>>>>>>>> checked via aptitude).
>>>>>>>> Still if I try to set groups permissions as in screenshot below, I
>>>>>>>> can't choose any existing group..
>>>>>>>> [image: Inline-Bild 1]
>>>>>>>> 12053 Berlin
>>>>>>>> Germany / Allemagne
>>>>>>>> 2015-05-04 13:19 GMT+02:00 Simone Dalmasso <
>>>>>>>>> Hi yes, is implemented and available in the ppa:geonode/testing.
>>>>>>>>> Beware that geonode 2.4 is available only on ubuntu 14.04.
>>>>>>>>> 2015-05-04 13:15 GMT+02:00 Rainer Lissewski <
>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>> Hi is the full groups permissions system implemented in 2.4 as
>>>>>>>>>> available in the ubuntu *ppa:geonode/testing *repo?
>>>>>>>>>>  I saw  https://github.com/GeoNode/geonode/pull/1406 and it
>>>>>>>>>> appears to be merged still on my 2.4 installation from abovementioned ppa
>>>>>>>>>> the functionality isnt there..
>>>>>>>>>> Kind regards
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/173be279/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/173be279/attachment-0001.png>
More information about the geonode-devel mailing list
