[GeoNode-devel] groups permissions in 2.4
Simone Dalmasso
simone.dalmasso at gmail.com
Tue May 5 02:11:57 PDT 2015
Ok so the problem seems to be that you have no groups.
How did you create the groups? The correct way is to create them through
the Groups section in GeoNode.
2015-05-05 11:08 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> Hi Simone, GroupProfile.objects.all() appears to be empty, this is my
> output:
> >>> from geonode.groups.models import GroupProfile
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-05 10:57 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Rainer,
>> I can't replicate the behavior, I create a group in the group tab and
>> then it's available in the autocomplete. The function that is handling that
>> is this one
>> https://github.com/GeoNode/geonode/blob/master/geonode/views.py#L70 and
>> it simply does a GroupProfile.objects.filter.
>> Can you try to run these commands:
>> $ geonode shell
>> and see whether it's correctly returning your groups.
>> 2015-05-05 10:26 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> Hi Simone,
>>> I installed 2.4.0+beta25 from the testing ppa and still I cant get any
>>> results from the groups autocomplete field. The response for the ajax
>>> request is {"count": 0, "users": [], "groups": []}
>>> I added an '*' to the the ALLOWED_HOSTS in local_settings.py, if thats
>>> of any importance for above problem.
>>> 12053 Berlin
>>> Germany / Allemagne
>>> 2015-05-04 14:31 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> super thanks! I'll just use a fresh vagrant vm
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> 2015-05-04 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Yes will overwrite the current one. I suggest you to use a new Ubuntu
>>>>> though. Because until we release the final the upgrade between versions may
>>>>> not be smooth.
>>>>> Il lunedì 4 maggio 2015, Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>> ha scritto:
>>>>>> oh wow! will this be available via ppa directly?
>>>>>> 12053 Berlin
>>>>>> Germany / Allemagne
>>>>>> 2015-05-04 13:35 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> weird, anyway I'm going to release e new beta today, you can install
>>>>>>> it and should solve. If you install it within 4 hours you'll get a faster
>>>>>>> and better geonode.
>>>>>>> 2015-05-04 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu
>>>>>>>> exactly, the autocomplete isnt working
>>>>>>>> 12053 Berlin
>>>>>>>> Germany / Allemagne
>>>>>>>> 2015-05-04 13:29 GMT+02:00 Simone Dalmasso <
>>>>>>>>> On my 2.4 after I create a group in the groups section then it
>>>>>>>>> will appear in the autocomplete. Is it not working for you?
>>>>>>>>> 2015-05-04 13:25 GMT+02:00 Rainer Lissewski <
>>>>>>>>>> Ok I installed on trusty 14.04 and it is 2.4.0+beta24 (just
>>>>>>>>>> checked via aptitude).
>>>>>>>>>> Still if I try to set groups permissions as in screenshot below,
>>>>>>>>>> I can't choose any existing group..
>>>>>>>>>> [image: Inline-Bild 1]
>>>>>>>>>> 12053 Berlin
>>>>>>>>>> Germany / Allemagne
>>>>>>>>>> 2015-05-04 13:19 GMT+02:00 Simone Dalmasso <
>>>>>>>>>>> Hi yes, is implemented and available in the ppa:geonode/testing.
>>>>>>>>>>> Beware that geonode 2.4 is available only on ubuntu 14.04.
>>>>>>>>>>> 2015-05-04 13:15 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>>>> Hi is the full groups permissions system implemented in 2.4 as
>>>>>>>>>>>> available in the ubuntu *ppa:geonode/testing *repo?
>>>>>>>>>>>> I saw https://github.com/GeoNode/geonode/pull/1406 and it
>>>>>>>>>>>> appears to be merged still on my 2.4 installation from abovementioned ppa
>>>>>>>>>>>> the functionality isnt there..
>>>>>>>>>>>> Kind regards
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/d37b1c20/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/d37b1c20/attachment-0001.png>
More information about the geonode-devel
