[GeoNode-devel] Group invite via email --> internal server error ( /groups/group/test/invite/)
Rainer Lissewski
rainerlissewski at gmail.com
Tue May 5 03:40:14 PDT 2015
Hi on trying to invite group members via email, I get an internal server
error from /groups/group/test/invite/
Apache log:
*[Tue May 05 05:21:11.374979 2015] [:error] [pid 20113:tid 140121475692288]
File "/usr/local/lib/python2.7/dist-packages/geonode/groups/models.py",
line 167, in invite*
*[Tue May 05 05:21:11.375008 2015] [:error] [pid 20113:tid 140121475692288]
invitation.send(from_user)*
*[Tue May 05 05:21:11.375079 2015] [:error] [pid 20113:tid 140121475692288]
AttributeError: 'GroupInvitation' object has no attribute 'send'*
*[Tue May 05 05:21:11.401051 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] mod_wsgi (pid=20113):
Exception occurred processing WSGI script
'/var/www/geonode/wsgi/geonode.wsgi'.*
*[Tue May 05 05:21:11.401079 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] Traceback (most recent
call last):*
*[Tue May 05 05:21:11.401101 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] File
"/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
in __call__*
*[Tue May 05 05:21:11.401129 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] response =
self.get_response(request)*
*[Tue May 05 05:21:11.401147 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
in get_response*
*[Tue May 05 05:21:11.401174 2015] [:error] [pid 20113:tid 140121475692288]
self.handle_uncaught_exception(request, resolver, sys.exc_info())*
*[Tue May 05 05:21:11.401191 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
in handle_uncaught_exception*
*[Tue May 05 05:21:11.401214 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] return
callback(request, **param_dict)*
*[Tue May 05 05:21:11.401231 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
_wrapped_view*
*[Tue May 05 05:21:11.401264 2015] [:error] [pid 20113:tid 140121475692288]
view_func(request, *args, **kwargs)*
*[Tue May 05 05:21:11.401297 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in
server_error*
*[Tue May 05 05:21:11.401322 2015] [:error] [pid 20113:tid 140121475692288]
http.HttpResponseServerError(template.render(Context({})))*
*[Tue May 05 05:21:11.401381 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
render*
*[Tue May 05 05:21:11.401406 2015] [:error] [pid 20113:tid 140121475692288]
self._render(context)*
*[Tue May 05 05:21:11.401422 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
_render*
*[Tue May 05 05:21:11.401444 2015] [:error] [pid 20113:tid 140121475692288]
self.nodelist.render(context)*
*[Tue May 05 05:21:11.401463 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
render*
*[Tue May 05 05:21:11.401486 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] bit =
self.render_node(node, context)*
*[Tue May 05 05:21:11.401503 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
render_node*
*[Tue May 05 05:21:11.401525 2015] [:error] [pid 20113:tid 140121475692288]
node.render(context)*
*[Tue May 05 05:21:11.401541 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53,
in render*
*[Tue May 05 05:21:11.401586 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] result =
*[Tue May 05 05:21:11.401604 2015] [:error] [pid 20113:tid 140121475692288]
render*
*[Tue May 05 05:21:11.401627 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401643 2015] [:error] [pid 20113:tid 140121475692288]
render_node*
*[Tue May 05 05:21:11.401665 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401697 2015] [:error] [pid 20113:tid 140121475692288]
155, in render*
*[Tue May 05 05:21:11.401720 2015] [:error] [pid 20113:tid 140121475692288]
self.render_template(self.template, context)*
*[Tue May 05 05:21:11.401737 2015] [:error] [pid 20113:tid 140121475692288]
137, in render_template*
*[Tue May 05 05:21:11.401759 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] output =
template.render(context)*
*[Tue May 05 05:21:11.401778 2015] [:error] [pid 20113:tid 140121475692288]
render*
*[Tue May 05 05:21:11.401800 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401817 2015] [:error] [pid 20113:tid 140121475692288]
_render*
*[Tue May 05 05:21:11.401838 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401855 2015] [:error] [pid 20113:tid 140121475692288]
render*
*[Tue May 05 05:21:11.401877 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401906 2015] [:error] [pid 20113:tid 140121475692288]
render_node*
*[Tue May 05 05:21:11.401929 2015] [:error] [pid 20113:tid 140121475692288]
*[Tue May 05 05:21:11.401946 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
line 24, in render*
*[Tue May 05 05:21:11.401969 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] request =
context["request"]*
*[Tue May 05 05:21:11.401994 2015] [:error] [pid 20113:tid 140121475692288]
"/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
__getitem__*
*[Tue May 05 05:21:11.402022 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] raise KeyError(key)*
*[Tue May 05 05:21:11.402043 2015] [:error] [pid 20113:tid 140121475692288]
[remote 10.0.2.2:16025 <http://10.0.2.2:16025/>] KeyError: 'request'*
*[Tue May 05 05:27:08.763694 2015] [:error] [pid 20114:tid 140121475692288]
Internal Server Error: /groups/group/test/invite/*
*[Tue May 05 05:27:08.763800 2015] [:error] [pid 20114:tid 140121475692288]
Traceback (most recent call last):*
*[Tue May 05 05:27:08.763872 2015] [:error] [pid 20114:tid 140121475692288]
File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py",
line 112, in get_response*
*[Tue May 05 05:27:08.763902 2015] [:error] [pid 20114:tid 140121475692288]
response = wrapped_callback(request, *callback_args, **callback_kwargs)*
*[Tue May 05 05:27:08.763956 2015] [:error] [pid 20114:tid 140121475692288]
File "/usr/lib/python2.7/dist-packages/django/views/decorators/http.py",
line 41, in inner*
*[Tue May 05 05:27:08.763985 2015] [:error] [pid 20114:tid 140121475692288]
return func(request, *args, **kwargs)*
*[Tue May 05 05:27:08.764012 2015] [:error] [pid 20114:tid 140121475692288]
File "/usr/local/lib/python2.7/dist-packages/geonode/groups/views.py",
line 182, in group_invite*
*[Tue May 05 05:27:08.764039 2015] [:error] [pid 20114:tid 140121475692288]
role=form.cleaned_data["invite_role"])*
*[Tue May 05 05:27:08.764067 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.764131 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.764158 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.791043 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] mod_wsgi (pid=20114): Exception occurred processing
WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.*
*[Tue May 05 05:27:08.791074 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] Traceback (most recent call last):*
*[Tue May 05 05:27:08.791100 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] File
in __call__*
*[Tue May 05 05:27:08.791179 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] response = self.get_response(request)*
*[Tue May 05 05:27:08.791212 2015] [:error] [pid 20114:tid 140121475692288]
in get_response*
*[Tue May 05 05:27:08.791238 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.791266 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.791290 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] return callback(request, **param_dict)*
*[Tue May 05 05:27:08.791310 2015] [:error] [pid 20114:tid 140121475692288]
_wrapped_view*
*[Tue May 05 05:27:08.791376 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] response = view_func(request, *args, **kwargs)*
*[Tue May 05 05:27:08.791396 2015] [:error] [pid 20114:tid 140121475692288]
server_error*
*[Tue May 05 05:27:08.791452 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.791472 2015] [:error] [pid 20114:tid 140121475692288]
render*
*[Tue May 05 05:27:08.791708 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] return self._render(context)*
*[Tue May 05 05:27:08.791730 2015] [:error] [pid 20114:tid 140121475692288]
_render*
*[Tue May 05 05:27:08.791755 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] return self.nodelist.render(context)*
*[Tue May 05 05:27:08.791774 2015] [:error] [pid 20114:tid 140121475692288]
render*
*[Tue May 05 05:27:08.791797 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] bit = self.render_node(node, context)*
*[Tue May 05 05:27:08.791821 2015] [:error] [pid 20114:tid 140121475692288]
render_node*
*[Tue May 05 05:27:08.791848 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] return node.render(context)*
*[Tue May 05 05:27:08.791869 2015] [:error] [pid 20114:tid 140121475692288]
in render*
*[Tue May 05 05:27:08.791948 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] result = self.nodelist.render(context)*
*[Tue May 05 05:27:08.791968 2015] [:error] [pid 20114:tid 140121475692288]
render*
*[Tue May 05 05:27:08.791992 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792009 2015] [:error] [pid 20114:tid 140121475692288]
render_node*
*[Tue May 05 05:27:08.792031 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792047 2015] [:error] [pid 20114:tid 140121475692288]
155, in render*
*[Tue May 05 05:27:08.792069 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] return self.render_template(self.template,
context)*
*[Tue May 05 05:27:08.792086 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792112 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] output = template.render(context)*
*[Tue May 05 05:27:08.792129 2015] [:error] [pid 20114:tid 140121475692288]
render*
*[Tue May 05 05:27:08.792151 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792168 2015] [:error] [pid 20114:tid 140121475692288]
_render*
*[Tue May 05 05:27:08.792188 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792205 2015] [:error] [pid 20114:tid 140121475692288]
render*
*[Tue May 05 05:27:08.792226 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792243 2015] [:error] [pid 20114:tid 140121475692288]
render_node*
*[Tue May 05 05:27:08.792264 2015] [:error] [pid 20114:tid 140121475692288]
*[Tue May 05 05:27:08.792281 2015] [:error] [pid 20114:tid 140121475692288]
line 24, in render*
*[Tue May 05 05:27:08.792329 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] request = context["request"]*
*[Tue May 05 05:27:08.792361 2015] [:error] [pid 20114:tid 140121475692288]
__getitem__*
*[Tue May 05 05:27:08.792478 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] raise KeyError(key)*
*[Tue May 05 05:27:08.792503 2015] [:error] [pid 20114:tid 140121475692288]
[remote xx.x.x.x:xxxxx] KeyError: 'request'*
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/639bc93a/attachment-0001.html>
More information about the geonode-devel
