[GeoNode-devel] [GeoNode-users] updatelayers not working: NoneType object has no attribute find
Florian Hoedt florian.hoedt at hs-owl.de
Mon Nov 2 03:01:25 PST 2015
Hello Alessio,
Thank you for your help! I´ve used this python snippet:
import pip
from subprocess import call
for dist in pip.get_installed_distributions():
    call("pip install --upgrade " + dist.project_name, shell=True)
to upgrade all my pip packages and this made the updatelayers command work.
mit freundlichen Grüßen
Florian Hoedt
B.Sc. Florian Hoedt
Hochschule Ostwestfalen-Lippe / Campus Höxter
FB 9 Landschaftsarchitektur und Umweltplanung
An der Wilhelmshöhe 44
37671 Höxter
Tel.: 05271-687-7478
E-Mail: florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>
www.hs-owl.de/fb9<http://www.hs-owl.de/fb9>
Von: alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com] Im Auftrag von Alessio Fabiani
Gesendet: Freitag, 30. Oktober 2015 16:14
An: Jeffrey Johnson
Cc: Florian Hoedt; geonode-devel at lists.osgeo.org
Betreff: Re: [GeoNode-users] updatelayers not working: NoneType object has no attribute find
There should be a fix for SLDs on latest gsconfig versions.
Try to update the dependencies with
pip install -e .
from the GeoNode updated folder.
I'll check the issue though.
Regards,
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Oct 29, 2015 at 4:00 PM, Jeffrey Johnson <ortelius at gmail.com<mailto:ortelius at gmail.com>> wrote:
Lets keep this on the list. Ill update the ticket and see if the
GeoSolutions guys have any ideas since they have been working on both
gsconfig and the imagemosaic plugin.
Jeff
On Thu, Oct 29, 2015 at 5:00 AM, Florian Hoedt <florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>> wrote:
> Hello Jeffrey,
> I tried to reopen the ticket but it seems like I am not allowed to do it (or I just do not know exactly what to click).
> Nevertheless here is the stacktrace:
> https://gist.github.com/gannebamm/1e1cd8442f90769d4c31
> The Layer is an imagemosaic datastore with the geoserver raster style as default style.
> Florian Hoedt
> B.Sc. Florian Hoedt
> 37671 Höxter
> -----Ursprüngliche Nachricht-----
> Von: Jeffrey Johnson [mailto:ortelius at gmail.com<mailto:ortelius at gmail.com>]
> Gesendet: Montag, 26. Oktober 2015 17:34
> An: Florian Hoedt
> Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>; geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
> Florian,
> Can you add your stack trace to the ticket and re-open?
> Jeff
> On Mon, Oct 26, 2015 at 2:44 AM, Florian Hoedt <florian.hoedt at hs-owl.de<mailto:florian.hoedt at hs-owl.de>> wrote:
>> Hello List,
>> Seems like this error still is present:
>> https://github.com/GeoNode/geonode/issues/869
>> I have created and deleted a lot of datastores in GeoServer (still learning) and after beeing happy with my aerials tried to:
>> sudo geonode updatelayers --skip-geonode-registered
>> which gave me:
>> Traceback (most recent call last):
>>   File "/usr/bin/django-admin", line 5, in <module>
>>     management.execute_from_command_line()
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
>>     utility.execute()
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 392, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 242, in run_from_argv
>>     self.execute(*args, **options.__dict__)
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 285, in execute
>>     output = self.handle(*args, **options)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py", line 108, in handle
>>     remove_deleted=remove_deleted)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 458, in gs_slurp
>>     "bbox_y1": Decimal(resource.latlon_bbox[3])
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 154, in get_or_create
>>     return self.get_queryset().get_or_create(**kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line 341, in get_or_create
>>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 383, in get_or_create
>>     obj.save(force_insert=True, using=self.db)
>>   File "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line 90, in save
>>     return super(PolymorphicModel, self).save(*args, **kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
>>     force_update=force_update, update_fields=update_fields)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 582, in save_base
>>     update_fields=update_fields, raw=raw, using=using)
>>   File "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185, in send
>>     response = receiver(signal=self, sender=sender, **named)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line 470, in geoserver_post_save
>>     set_styles(instance, gs_catalog)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 777, in set_styles
>>     layer.default_style = save_style(default_style)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 792, in save_style
>>     style.sld_title = gs_style.sld_title
>>   File "/usr/lib/python2.7/dist-packages/geoserver/style.py", line 49, in sld_title
>>     title_node = user_style.find("{http://www.opengis.net/sld}Title<http://www.opengis.net/sld%7dTitle>")
>> Exception: ('Failed to process DOP Hx 2014', AttributeError("'NoneType' object has no attribute 'find'",))
>> I use the raster sld as default renderer. The layer DOP Hx 2014 is an RGB ImageMosaic Datastore.
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151102/a783e3bc/attachment-0001.html>
More information about the geonode-devel mailing list
