[GeoNode-devel] Adding GeoServer XStreamPersisterInitializer
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Oct 5 08:48:26 PDT 2015
Dear all,
in order to align the GeoServer Auth module for GeoNode with the latest
version of GeoServer 2.7.x, we need to introduce a new class allowing
XStream to recognize the module classes as trustable and secure.
This is due to the recent security updates made in GeoServer.
The PR doing this is the following one, can someone merge it?
https://github.com/GeoNode/geoserver-geonode-ext/pull/45
By the way, the Continuous Build was failing since some time
http://build.geonode.org/job/geoserver-geonode-dev/
but at least me did not recognize the failures since the serve does not
send any email to the devel list.
It would be possible to add to the Jenkins jobs the possibility of sending
failure emails to the GeoNode Dev list?
Thanks.
Best Regards,
Alessio Fabiani.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151005/16fb5364/attachment.html>
More information about the geonode-devel mailing list
