[GeoNode-devel] bing api request denied
Simone Dalmasso simone.dalmasso at gmail.com
Thu Oct 8 05:34:09 PDT 2015
Here the two commands that you can type in a "geonode shell" (for a
standard geonode installation) to remove bing from existing maps.
>>> from geonode.maps.models import MapLayer
>>> MapLayer.objects.filter(name=u'AerialWithLabels').delete()
Hope this helps
2015-10-07 16:06 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Paolo that's right :(
> 2015-10-07 15:57 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Thanks to both
>> for system in productions containing existing maps I think the only way
>> is to follow Bart's suggestion or running a script able to remove the Bing
>> map baselayer from any existing map.
>> cheers
>> p
>> On Wed, Oct 7, 2015 at 3:51 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Thanks Bart,
>>> then is good to keep it disabled by default and add instructions on how
>>> to properly add it.
>>> 2015-10-07 15:50 GMT+02:00 Bart van den Eijnden <
>>> bartvde at boundlessgeo.com>:
>>>> Ideally you would have requested your own API key for your site on
>>>> https://www.bingmapsportal.com
>>>> And then configure the gxp Bing source with the apiKey property /
>>>> config.
>>>> Best regards,
>>>> Bart
>>>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>>>> 1-877-673-6436 <917-460-7207>
>>>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>>>> <http://boundlessgeo.com>
>>>> On 07 Oct 2015, at 15:41, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>> wrote:
>>>> Dears,
>>>> from yesterday the bing maps api that are used by default in every
>>>> GeoNode map are not working anymore due to a request denied. The effect is
>>>> that every map in GeoNode cannot be zoomed properly anymore.
>>>> While we try to figure out what is the cause of this we suggest a quick
>>>> fix,
>>>> open your GeoNode settings  (/etc/geonode/local_settings.py for a
>>>> standard apt-get installation) and comment the following lines like we
>>>> already did on master
>>>> https://github.com/GeoNode/geonode/commit/f2707e64e78931b31a06016a3e04f1ba76021b66 then
>>>> restart the web server.
>>>> We appreciate any comment and feedback.
>>>> Simone
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>> Simone
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151008/30954af4/attachment.html>
More information about the geonode-devel mailing list
