[GeoNode-devel] Doubt in GeoNode's installation
Jeffrey Johnson
ortelius at gmail.com
Fri Oct 9 18:28:57 PDT 2015
Did you see any output when you ran sudo apt-get install geonode? If
so, what did it say? If not, what does it say when you try that
command again?
On Fri, Oct 9, 2015 at 4:51 PM, Bárbara Ferreira <arabrab.geo at gmail.com> wrote:
> Hi,
> I installed GeoNode using the Quick Start (Get Started Now) tutorial for
> Ubuntu 14.4.
> After that I tried to access the GeoNode through this link:
> http://localhost:8000
> ... And nothing happens.
> I don't know how to continue ...
> I did this "simple" installation (Quick Start) of GeoNode, but for my
> project I need administrator or developer installation (in Ubuntu 14.04).
> What would be the next step? Administrator or developer tutorial. In both
> case, in which step I must continue?
> Thanks.
> Regards
> Bárbara F
> erreira
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel
