[GeoNode-devel] Doubt in GeoNode's installation
Bárbara Ferreira
arabrab.geo at gmail.com
Fri Oct 9 21:23:08 PDT 2015
I got it!
Thank you so much!
But I'm still with doubts about the continuation of the installation
administration or development.
Em 09/10/2015 23:41, "Jeffrey Johnson" <ortelius at gmail.com> escreveu:
> Ha, please check on just http://localhost not on port 8000
> On Fri, Oct 9, 2015 at 7:13 PM, Bárbara Ferreira <arabrab.geo at gmail.com>
> wrote:
> > Hi, Jeffrey.
> > I have done steps 1 and 2 of the quick installation of GeoNode (attached)
> > After this I entered the "http: // localhost: 8000" but does not work
> > After these steps (1 and 2), I do not know what to do:
> > I do not know if I did right to access "http: // localhost: 8000" after
> the
> > steps (1 and 2).
> > Or should I install the administrator or developer after the steps (1 and
> > 2)?
> > Em 09/10/2015 22:28, "Jeffrey Johnson" <ortelius at gmail.com> escreveu:
> >> Did you see any output when you ran sudo apt-get install geonode? If
> >> so, what did it say? If not, what does it say when you try that
> >> command again?
> >> On Fri, Oct 9, 2015 at 4:51 PM, Bárbara Ferreira <arabrab.geo at gmail.com
> >> wrote:
> >> > Hi,
> >> > I installed GeoNode using the Quick Start (Get Started Now) tutorial
> for
> >> > Ubuntu 14.4.
> >> > After that I tried to access the GeoNode through this link:
> >> > http://localhost:8000
> >> > ... And nothing happens.
> >> > I don't know how to continue ...
> >> > I did this "simple" installation (Quick Start) of GeoNode, but for my
> >> > project I need administrator or developer installation (in Ubuntu
> >> > 14.04).
> >> > What would be the next step? Administrator or developer tutorial. In
> >> > both
> >> > case, in which step I must continue?
> >> > Thanks.
> >> > Regards
> >> > Bárbara F
> >> > erreira
> >> > _______________________________________________
> >> > geonode-devel mailing list
> >> > geonode-devel at lists.osgeo.org
> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151010/8f5912c7/attachment.html>
More information about the geonode-devel
