[GeoNode-devel] Time to do a Beta and a Release
Ariel Nunez ingenieroariel at gmail.com
Fri Sep 25 09:11:12 PDT 2015
I can take care of releasing the artifacts (or make sure whoever wants to
do it has the right permissions over there)
-a
On Fri, Sep 25, 2015 at 9:43 AM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> maybe gsconfig 7.0.0 and gsimporter 1.0.0
> On Fri, Sep 25, 2015 at 9:39 AM, Tyler Garner <garnertb at prominentedge.com>
> wrote:
>> We should figure this out too before releasing:
>> https://github.com/boundlessgeo/gsconfig/issues/91.
>> I think we should switch to semver for both of the packages.
>> On Fri, Sep 25, 2015 at 10:37 AM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> Ariel, can you add Daniel, Alessio and Tyler as owners/maintainers on
>>> pypi?
>>> On Fri, Sep 25, 2015 at 7:18 AM, Daniel Berry <dberry at boundlessgeo.com>
>>> wrote:
>>>> Yep, Ariel will need to do that. It might be wise to add a few other
>>>> people as owners or maintainers to both gsconfig and gsimporter.
>>>> On Fri, Sep 25, 2015 at 9:00 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>> wrote:
>>>>> I believe so. Daniel, if you can make the releases to Pypi, please go
>>>>> for it. Otherwise we may need help from Ariel.
>>>>> On Fri, Sep 25, 2015 at 6:59 AM, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Yes IMHO
>>>>>> -A.
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/NWWaa2 for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via Poggio alle Viti 1187
>>>>>> 55054  Massarosa (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39  331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The sender
>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> On Fri, Sep 25, 2015 at 3:57 PM, Daniel Berry <
>>>>>> dberry at boundlessgeo.com> wrote:
>>>>>>> In regards to the gsimporter and gsconfig are we at a point where we
>>>>>>> can update pypi.
>>>>>>> I loaded both on testpypi
>>>>>>> gsimporter - https://testpypi.python.org/pypi/gsimporter/0.2
>>>>>>> gsconfig - https://testpypi.python.org/pypi/gsconfig/0.6.14
>>>>>>> Dan
>>>>>>> On Fri, Sep 25, 2015 at 4:04 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi Alessio
>>>>>>>> > On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>>> wrote:
>>>>>>>> >> I agree to start releasing a new beta (beta 27) and maybe start
>>>>>>>> >> thinking about releasing a RC1 (time is short to the sprint).
>>>>>>>> >> By the way: I see several issues still open regarding GeoServer
>>>>>>>> >> integration [1], maybe it would be great to do a triage to check
>>>>>>>> what
>>>>>>>> >> it was fixed and what it was not.
>>>>>>>> >> Personally I see #2177 as a blocker to move our production to GS
>>>>>>>> 2.7.
>>>>>>>> > I did not have the chance to look deeply in to this yet, but at a
>>>>>>>> first
>>>>>>>> > glance I'm not fully sure this depends on GS. It seems to be more
>>>>>>>> an issue
>>>>>>>> > on GeoNode side. Do you have any more details? In any case I'll
>>>>>>>> try to find
>>>>>>>> > some time to inspect this issue as soon as possible. (Also, make
>>>>>>>> a try using
>>>>>>>> > the very latest versions of gsconfig and gsimporter, the
>>>>>>>> communication
>>>>>>>> > between the client and GeoServer has several fixes and
>>>>>>>> improvements which
>>>>>>>> > maybe already fixed this issue too)
>>>>>>>> we can look into this at the sprint, and yes you are correct, it is
>>>>>>>> just Django, sorry for the confusion.
>>>>>>>> >> Is the SQL security backend correctly working with GS 2.7 [2]?
>>>>>>>> > Never tested. Can you please send me few lines and details in
>>>>>>>> order to test
>>>>>>>> > and troubleshoot this?
>>>>>>>> http://docs.geonode.org/en/dev/deploy/production.html#installing-the-stored-procedure
>>>>>>>> hope it helps
>>>>>>>> cheers
>>>>>>>> p
>>>>>>>> Paolo Corti
>>>>>>>> Geospatial software developer
>>>>>>>> web: http://www.paolocorti.net
>>>>>>>> twitter: @capooti
>>>>>>>> skype: capooti
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>> *Daniel Berry*
>>>>>>> Professional Services Engineer | Boundless
>>>>>>> 512-468-3946 (cell)
>>>>>>> @boundlessgeo
>>>> *Daniel Berry*
>>>> 512-468-3946 (cell)
>>>> @boundlessgeo
>> *Tyler Garner*
>> Co-Founder | Prominent Edge
>> Office: 703-743-5434
>> Mobile: 434-841-3803
>> prominentedge.com
> *Daniel Berry*
> 512-468-3946 (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150925/acb680ae/attachment.html>
More information about the geonode-devel mailing list
