[GeoNode-devel] Update the BBOX of an existing layer
Dimitris Karakostis
karakostis.dimitris at gmail.com
Thu Aug 4 05:10:13 PDT 2016
I am working on the development of a functionality where the user can
add/edit the location of existing features (points etc.)
When I add the new point then I use the <<recalculate>> parameter (from
geoserver) in order to update the BBOX in the geoserver.
But I can not find out how to update the BBOX stored in the CSW.
I have found out, that if I manually update the layer's metadata, then the
BBOX in the model is replaced with the correct one.
But looking at the layer_metadata view, I am not sure, which is the
function that actually does this.
Can someone point me to the right direction?
Thanks.
Dimitris
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160804/45976232/attachment.html>
More information about the geonode-devel
