[GeoNode-devel] Thumbnail update fails
Guillaume Sueur
no-reply at neogeo-online.net
Mon Aug 29 07:13:14 PDT 2016
Hey, I think I've got something here !
If I use the geoserver.war from
http://build.geonode.org/geoserver/latest/, it's all fine, but if I take
the geoserver-2.9.x.war, it doesn't work...
Le 29/08/2016 à 15:54, Francesco Bartoli a écrit :
> Just notice such build has a special security provider for the
> authentication from django https://github.com/GeoNode/geoserver-geonode-ext
> Francesco
> Il giorno 29/ago/2016, alle ore 15:44, Guillaume Sueur
> <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>> ha scritto:
>> I'm gonna try with
>> http://build.geonode.org/geoserver/latest/geoserver.war and see what
>> happens.
>> Thanks for your kind advices
>> Guillaume
>> Le 29/08/2016 à 15:40, Francesco Bartoli a écrit :
>>> Maybe you can try with the official stable version 2.9.1 of geoserver
>>> just making the operations manually with curl and see if the problem is
>>> still happening careless of geonode.
>>> Regards,
>>> Francesco
>>> Il giorno 29/ago/2016, alle ore 15:32, Simone Dalmasso
>>> <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>
>>> <mailto:simone.dalmasso at gmail.com>> ha scritto:
>>>> Indeed is strange. Try to delete geoserver and the war file and run
>>>> paver setup again. Let's see how it goes with a new one. (save your
>>>> data dir if needed)
>>>> 2016-08-29 15:28 GMT+02:00 Guillaume Sueur
>>>> <mailto:no-reply at neogeo-online.net>>:
>>>> Hi again,
>>>> It's really weird. It seems that the printing module is correctly
>>>> activated (geoserver/pdf/info.json sends some content,
>>>> corresponding to
>>>> the correct config.yaml file).
>>>> But it's like the bindings with the REST API is not done. On another
>>>> instance, if I request
>>>> localhost:8080/geoserver/rest/printng/render.png
>>>> I have an empty PNG in return. On this one, I keep having this
>>>> damn 405
>>>> error, just because it is not recognized by the REST API I guess.
>>>> Any clue here ? Maybe I should ask the Geoserver mailing list. It's
>>>> always hard to guess with these cross-software / configuration
>>>> problems.
>>>> Best regards
>>>> Guillaume
>>>> Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
>>>>> And if you open that url in your browser you get a 405 too?
>>>>> In the layer detail page a 405 on /rest/styles is expected and is the
>>>>> correct behavior. But not more than one.
>>>>> 2016-08-29 13:52 GMT+02:00 Guillaume Sueur
>>>> <mailto:no-reply at neogeo-online.net>>>:
>>>>> Hi, thanks for your reply,
>>>>> Nothing shows up in the log, even in developer logging mode.
>>>>> Anyway, what is strange is that I get a 405 error (method not
>>>>> allowed)
>>>>> and not a 401 (authentication needed). The requested URL is correct
>>>>> though... :
>>>>> http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180
>>>> <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>
>>>> <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>>
>>>>> (auth account and realm are correct too).
>>>>> Best regards
>>>>> Guillaume
>>>>> Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
>>>>>> Hi, try to take a look at the geoserver logs to see if there is a
>>>>>> problem with authenticating with geonode or a missing permission
>>>>> (but I
>>>>>> don't think). It may just be a small misconfiguration in geoserver.
>>>>>> Hope this helps
>>>>> http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
>>>> <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse>
>>>>> .org%2Cguillaume%2Ccatch22&height=180
>>>>> .org%2Cguillaume%2Ccatch22&height=180>
>>>>>> 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
>>>> <mailto:no-reply at neogeo-online.net>>>>:
>>>>>> Hi list,
>>>>>> I am experiencing a weird problem with geonode and
>>>> geoserver
>>>>> rest API.
>>>>>> Here is the story. I have a bunch of layers in
>>>> Geoserver, and
>>>>> I can
>>>>>> updatelayers from Geonode without any problem, having the
>>>>> thumbnails
>>>>>> correctly created in uploaded/thumbs directory, and
>>>> correctly
>>>>> set to
>>>>>> www-data ownership afterwards to avoid any problem when
>>>>> updating from
>>>>>> the web interface.
>>>>>> Then, if I use the "Define Thumbnail" button from the
>>>> Layer
>>>>> Edit Window,
>>>>>> an empty image is created over the previously created
>>>>> thumbnail. I dig a
>>>>>> bit into the code trying to locate the issue. It seems it
>>>>> comes from
>>>>>> geoserver api which replies to the request emitted in
>>>>>> geoserver/helpers.py on line 1687 with :
>>>>>> Thumbnail created : {'date': 'Mon, 29 Aug 2016
>>>> 10:19:56 GMT',
>>>>> 'status':
>>>>>> '405', 'content-length': '0'
>>>>>> , 'allow': 'GET', 'server':
>>>> 'Noelios-Restlet-Engine/1.0..8'}
>>>>>> which means that the Method Not allowed error wasn't
>>>> caught back
>>>>>> correctly by geonode who continued the process and
>>>> wrote the empty
>>>>>> content to a new file.
>>>>>> I just don't understand why I received this 405 HTTP
>>>> error in this
>>>>>> situation, that I have seen working well on other Geonode
>>>>> Instances.
>>>>>> I've made the installation following the custom
>>>> installation
>>>>> guide last
>>>>>> week, so I guess with some fresh github code.
>>>>>> Any clue ?
>>>>>> Best regards
>>>>>> Guillaume
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> <mailto:geonode-devel at lists.osgeo.org>
>>>> <mailto:geonode-devel at lists.osgeo.org>>
>>>> <mailto:geonode-devel at lists.osgeo.org>>>
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>>
>>>>>> Simone
>>>>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
>>>>> Simone
>>>> Simone
More information about the geonode-devel
