[GeoNode-devel] Thumbnail update fails
Daniel Berry
dberry at boundlessgeo.com
Mon Aug 29 14:11:34 PDT 2016
Francesco,
You are correct Java 8 is only required if using GeoGig in GeoServer 2.9.
Thanks for the reminder!
On Mon, Aug 29, 2016 at 8:55 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi Dan,
> uhm I don’t think so, in such a case geoserver log should have to reclaim
> with an unsupported major.minor exception
> Ciao
> Francesco
> Il giorno 29/ago/2016, alle ore 17:59, Daniel Berry <
> dberry at boundlessgeo.com> ha scritto:
> 2.9 requires Java 8, maybe that is the issue?
> Dan
> On Mon, Aug 29, 2016 at 4:59 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> First question: with the CURL command, are you using a login:password of
>> an ADMINISTRATOR? If not we already found the issue, since by default the
>> GeoServer REST security is configured like the following
>> /rest/process/batchdownload/download/*;GET=IS_AUTHENTICATED_ANONYMOUSLY
>> /**;GET=IS_AUTHENTICATED_ANONYMOUSLY
>> /**;POST,DELETE,PUT=ROLE_ADMINISTRATOR
>> This should be valid for old version too.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Mon, Aug 29, 2016 at 4:35 PM, Guillaume Sueur <
>> no-reply at neogeo-online.net> wrote:
>>> Sure, it is not really complicated.
>>> Just deploy the war, and see what you get at
>>> curl -u login:password -X POST
>>> http://localhost:8080/geoserver/rest/printng/render.png
>>> if you have an ugly dump of PNG content (like �PNG
>>> IHDJ�Y0�IDATx���1 �0� �DB���)
>>> it means that the rest print bindings works.
>>> If you don't get anything, add the -v option to cURL, the response
>>> header should tell you :
>>> < HTTP/1.1 405 Method Not Allowed
>>> < Allow: GET
>>> < Date: Mon, 29 Aug 2016 14:34:39 GMT
>>> * Server Noelios-Restlet-Engine/1.0..8 is not blacklisted
>>> < Server: Noelios-Restlet-Engine/1.0..8
>>> < Transfer-Encoding: chunked
>>> Best regards
>>> Guillaume
>>> Le 29/08/2016 à 16:22, Alessio Fabiani a écrit :
>>> > Hello all,
>>> > geoserver.war is 2.7.x version.
>>> > I'll take a look at the 2.9.x one. Maybe it's a security configuration
>>> > issue on the REST module.
>>> > Can you please write here how exactly I can reproduce the issue?
>>> > Best Regards,
>>> > Alessio Fabiani.
>>> > @alfa7691
>>> > GeoSolutions S.A.S.
>>> > Italy
>>> messaggio,
>>> messaggio
>>> > stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
>>> > copiarlo, od utilizzarlo per finalità diverse, costituisce
>>> comportamento
>>> > contrario ai principi dettati dal D.Lgs. 196/2003.
>>> > confidential or proprietary in nature or covered by the provisions of
>>> > privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
>>> Data
>>> > Protection Code).Any use not in accord with its purpose, any
>>> disclosure,
>>> > reproduction, copying, distribution, or either dissemination, either
>>> > whole or partial, is strictly forbidden except previous formal approval
>>> > of the named addressee(s). If you are not the intended recipient,
>>> please
>>> > contact immediately the sender by telephone, fax or e-mail and delete
>>> > the information in this message that has been received in error. The
>>> > sender does not give any warranty or accept liability as the content,
>>> > accuracy or completeness of sent messages and accepts no responsibility
>>> > for changes made after they were sent or for other risks which arise as
>>> > a result of e-mail transmission, viruses, etc.
>>> > On Mon, Aug 29, 2016 at 4:13 PM, Guillaume Sueur
>>> > <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>>
>>> wrote:
>>> > Hey, I think I've got something here !
>>> > If I use the geoserver.war from
>>> > http://build.geonode.org/geoserver/latest/
>>> > <http://build.geonode.org/geoserver/latest/>, it's all fine, but
>>> if
>>> > I take
>>> > the geoserver-2.9.x.war, it doesn't work...
>>> > Le 29/08/2016 à 15:54, Francesco Bartoli a écrit :
>>> > > Just notice such build has a special security provider for the
>>> > > authentication from django https://github.com/GeoNode/geo
>>> server-geonode-ext
>>> > <https://github.com/GeoNode/geoserver-geonode-ext>
>>> > > Francesco
>>> > > Il giorno 29/ago/2016, alle ore 15:44, Guillaume Sueur
>>> > <mailto:no-reply at neogeo-online.net>>> ha scritto:
>>> > >> I'm gonna try with
>>> > >> http://build.geonode.org/geoserver/latest/geoserver.war
>>> > <http://build.geonode.org/geoserver/latest/geoserver.war> and see
>>> what
>>> > >> happens.
>>> > >> Thanks for your kind advices
>>> > >> Guillaume
>>> > >> Le 29/08/2016 à 15:40, Francesco Bartoli a écrit :
>>> > >>> Maybe you can try with the official stable version 2.9.1 of
>>> > geoserver
>>> > >>> just making the operations manually with curl and see if the
>>> > problem is
>>> > >>> still happening careless of geonode.
>>> > >>> Regards,
>>> > >>> Francesco
>>> > >>> Il giorno 29/ago/2016, alle ore 15:32, Simone Dalmasso
>>> > >>> <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>
>>> > <mailto:simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.
>>> com>>
>>> > <mailto:simone.dalmasso at gmail.com>>> ha scritto:
>>> > >>>> Indeed is strange. Try to delete geoserver and the war file
>>> and run
>>> > >>>> paver setup again. Let's see how it goes with a new one.
>>> (save your
>>> > >>>> data dir if needed)
>>> > >>>> 2016-08-29 15:28 GMT+02:00 Guillaume Sueur
>>> .net>
>>> > <mailto:no-reply at neogeo-online.net <mailto:no-reply at neogeo-online
>>> .net>>
>>> > <mailto:no-reply at neogeo-online.net>>>:
>>> > >>>> Hi again,
>>> > >>>> It's really weird. It seems that the printing module is
>>> > correctly
>>> > >>>> activated (geoserver/pdf/info.json sends some content,
>>> > >>>> corresponding to
>>> > >>>> the correct config.yaml file).
>>> > >>>> But it's like the bindings with the REST API is not done.
>>> On
>>> > another
>>> > >>>> instance, if I request
>>> > >>>> I have an empty PNG in return. On this one, I keep having
>>> this
>>> > >>>> damn 405
>>> > >>>> error, just because it is not recognized by the REST API I
>>> > guess.
>>> > >>>> Any clue here ? Maybe I should ask the Geoserver mailing
>>> > list. It's
>>> > >>>> always hard to guess with these cross-software /
>>> configuration
>>> > >>>> problems.
>>> > >>>> Best regards
>>> > >>>> Guillaume
>>> > >>>> Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
>>> > >>>>> And if you open that url in your browser you get a 405 too?
>>> > >>>>> In the layer detail page a 405 on /rest/styles is expected
>>> and
>>> > is the
>>> > >>>>> correct behavior. But not more than one.
>>> > >>>>> 2016-08-29 13:52 GMT+02:00 Guillaume Sueur
>>> .net>>
>>> > <mailto:no-reply at neogeo-online.net>>>>:
>>> > >>>>> Hi, thanks for your reply,
>>> > >>>>> Nothing shows up in the log, even in developer logging
>>> mode.
>>> > >>>>> Anyway, what is strange is that I get a 405 error (method
>>> not
>>> > >>>>> allowed)
>>> > >>>>> and not a 401 (authentication needed). The requested URL
>>> is
>>> > correct
>>> > >>>>> though... :
>>> > http://localhost:8080/geoserver/rest/printng/render.png?wid
>>> th=240&auth=*************************&height=180
>>> > <http://localhost:8080/geoserver/rest/printng/render.png?wi
>>> dth=240&auth=*************************&height=180>
>>> dth=240&auth=*************************&height=180>>
>>> dth=240&auth=*************************&height=180>>>
>>> > >>>>> (auth account and realm are correct too).
>>> > >>>>> Best regards
>>> > >>>>> Guillaume
>>> > >>>>> Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
>>> > >>>>>> Hi, try to take a look at the geoserver logs to see if
>>> there is a
>>> > >>>>>> problem with authenticating with geonode or a missing
>>> permission
>>> > >>>>> (but I
>>> > >>>>>> don't think). It may just be a small misconfiguration in
>>> > geoserver.
>>> > >>>>>> Hope this helps
>>> th=240&auth=geonode.aua-toulouse
>>> dth=240&auth=geonode.aua-toulouse>
>>> dth=240&auth=geonode.aua-toulouse>>
>>> > >>>>> .org%2Cguillaume%2Ccatch22&height=180
>>> > >>>>> .org%2Cguillaume%2Ccatch22&height=180>
>>> > >>>>>> 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
>>> .net>>
>>> > <mailto:no-reply at neogeo-online.net>>>>>:
>>> > >>>>>> Hi list,
>>> > >>>>>> I am experiencing a weird problem with geonode and
>>> > >>>> geoserver
>>> > >>>>> rest API.
>>> > >>>>>> Here is the story. I have a bunch of layers in
>>> > >>>> Geoserver, and
>>> > >>>>> I can
>>> > >>>>>> updatelayers from Geonode without any problem, having the
>>> > >>>>> thumbnails
>>> > >>>>>> correctly created in uploaded/thumbs directory, and
>>> > >>>> correctly
>>> > >>>>> set to
>>> > >>>>>> www-data ownership afterwards to avoid any problem when
>>> > >>>>> updating from
>>> > >>>>>> the web interface.
>>> > >>>>>> Then, if I use the "Define Thumbnail" button from the
>>> > >>>> Layer
>>> > >>>>> Edit Window,
>>> > >>>>>> an empty image is created over the previously created
>>> > >>>>> thumbnail. I dig a
>>> > >>>>>> bit into the code trying to locate the issue. It seems it
>>> > >>>>> comes from
>>> > >>>>>> geoserver api which replies to the request emitted in
>>> > >>>>>> geoserver/helpers.py on line 1687 with :
>>> > >>>>>> Thumbnail created : {'date': 'Mon, 29 Aug 2016
>>> > >>>> 10:19:56 GMT',
>>> > >>>>> 'status':
>>> > >>>>>> '405', 'content-length': '0'
>>> > >>>>>> , 'allow': 'GET', 'server':
>>> > >>>> 'Noelios-Restlet-Engine/1.0..8'}
>>> > >>>>>> which means that the Method Not allowed error wasn't
>>> > >>>> caught back
>>> > >>>>>> correctly by geonode who continued the process and
>>> > >>>> wrote the empty
>>> > >>>>>> content to a new file.
>>> > >>>>>> I just don't understand why I received this 405 HTTP
>>> > >>>> error in this
>>> > >>>>>> situation, that I have seen working well on other Geonode
>>> > >>>>> Instances.
>>> > >>>>>> I've made the installation following the custom
>>> > >>>> installation
>>> > >>>>> guide last
>>> > >>>>>> week, so I guess with some fresh github code.
>>> > >>>>>> Any clue ?
>>> > >>>>>> Best regards
>>> > >>>>>> Guillaume
>>> > >>>>>> _______________________________________________
>>> > >>>>>> geonode-devel mailing list
>>> > >>>>>> geonode-devel at lists.osgeo.org
>>> > <mailto:geonode-devel at lists.osgeo.org>
>>> > <mailto:geonode-devel at lists.osgeo.org>>
>>> > <mailto:geonode-devel at lists.osgeo.org>>>
>>> > <mailto:geonode-devel at lists.osgeo.org>>>>
>>> > >>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>>> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
>>> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>>
>>> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>>>
>>> > >>>>>> Simone
>>> > >>>>> Simone
>>> > >>>> Simone
>>> > geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.os
>>> geo.org>
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
*Daniel Berry*
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160829/ef51c57f/attachment-0001.html>
More information about the geonode-devel
