[GeoNode-devel] Working on GeoServer OAuth2 authentication
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Aug 30 04:07:38 PDT 2016
Dear all,
working on a refactoring of the GeoNode-GeoServer Auth subsystem, the idea
would be to use the OAuth2 Protocol to allow GeoServer grab the
Authorizations from GeoNode (or from a common OAuth2 Provider).
The first step is to allow GeoServer to authenticate through the OAuth2
Protocol.
I just finished (almost) a new GeoServer extension allowing users to do
that.
Here [1] you can find a community module allowing GeoServer to authenticate
through the OAuth2 protocol.
The basic "oauth2" module contains the general infrastructure.
The "oauth2-google" module is an extension showing how is possible to use
Google OAuth2 Provider to authenticate and validate the "access_token".
Moreover the Security Filter also "simulates" an SSO based on OAuth2 by
injecting a provided "access_token" (which is then validated against the
configured OAuth2 Provider) similar to the GeoServer "AuthKey" module.
How the OAuth2 Filter works
1. The GeoServer GUI allows to configure the OAuth2 Service connection
parameters and select the GeoServer UserRoleService to use
2. The new filter may be added to the standard GeoServer Filter Chain
3. If not authenticated, GeoServer redirects the user automatically to the
Google Login Page
4. The OAuth2 Protocol asks for Authorizations
5. Accepting the authorization, the user is redirected to the GeoServer
endpoint
Best Regards,
Alessio Fabiani.
[1] - https://github.com/geosolutions-it/geoserver/tree/oauth2-filter
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160830/6e9ac8e1/attachment.html>
More information about the geonode-devel
