[GeoNode-devel] Support for additional types in upload
Jivan Amara development at jivanamara.net
Mon Dec 12 11:21:36 PST 2016
No worries; I wasn't contacting you to say you shouldn't move forward;
just that you should join in and implement your ideas on the importer
instead of directly in GeoNode.  It will be a bit before I turn my
attention to enabling fgdb imports.  Definitely get in touch if you plan
to move forward.  If it's down the road some I'd be happy to work
together, if it's sooner I can offer some support to get you going with
the importer.
Best, Jivan
On 12/12/2016 07:07 AM, Simone Dalmasso wrote:
> Rollback, apologyze,
> you are working on the importer already, so I'll leave to who is
> directly involved too.
> Thanks!
> 2016-12-12 16:01 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com
> <mailto:simone.dalmasso at gmail.com>>:
>     Hi Jivan,
>     this interesting indeed, though the community is working on
>     the https://github.com/GeoNode/django-osgeo-importer
>     <https://github.com/GeoNode/django-osgeo-importer> which will be
>     used in GeoNode soon as default way to import data. Do you think
>     that your work can fit in that one?
>     2016-12-05 19:59 GMT+01:00 Jivan Amara <development at jivanamara.net
>     <mailto:development at jivanamara.net>>:
>         > Message: 1
>         > Date: Fri, 25 Nov 2016 15:52:17 +0000
>         > From: Eric Groning <eg at novel-t.ch <mailto:eg at novel-t.ch>>
>         > To: "geonode-devel at lists.osgeo.org
>         <mailto:geonode-devel at lists.osgeo.org>"
>         <geonode-devel at lists.osgeo.org
>         <mailto:geonode-devel at lists.osgeo.org>>
>         > Subject: [GeoNode-devel] Support for additional types in upload
>         > Message-ID:
>          <VI1PR04MB1181179E9070D8AD3FE1F96FFA890 at VI1PR04MB1181.eurprd04.prod.outlook.com
>         <mailto:VI1PR04MB1181179E9070D8AD3FE1F96FFA890 at VI1PR04MB1181.eurprd04.prod.outlook.com>>
>         > Content-Type: text/plain; charset="iso-8859-1"
>         > Hello,
>         > I'm currently adding FGDB support for the upload for a
>         project based on a customized geonode.  Since it might be a
>         feature the community is interested in, I figured it's worth
>         it to mention in this list.  I also have a few questions.
>         > First, here is a rough outline of what I'm changing:
>         > -Use gdal 2.1.2 (the latest) compiled with FileGDB support
>         (via GDAL_LIBRARY_PATH in Django settings)
>         > -Change layer forms / upload / geoserver signals to accept a
>         zipped fgdb
>         > -Change geoserver_pre_save to use call ogr2ogr directly to
>         convert the FGDB to the geoserver data Postgis database (as
>         geoserver won't convert an uploaded FGDB as it does with
>         shapefiles)
>         > Second, with regards to adding this to geonode via pull request:
>         > The implementation I'm doing wouldn't really be directly
>         merge-able.  To do this properly, there would likely need to
>         be some refactoring done to make the upload generic and
>         extensible (like to easily add more gdal supported types with
>         different file structures / extentions such as KML / Postgis
>         backups / GML / SqLite / GeoJSON / etc).   The configuration
>         would have impacts on how the upload form is validated, the
>         layer upload javascript, the model, and how the layer is
>         uploaded to geoserver.  So not a light / easy change :)
>         > A side issue is that for some formats, you can have multiple
>         layers.  As such, it would be nice to have the UI handle
>         multiple layers (ie let the user choose which layers to upload)
>         > For reference, below are links to some shapefile specific
>         handling in the code --
>         https://github.com/GeoNode/geonode/blob/master/geonode/layers/utils.py#L94
>         <https://github.com/GeoNode/geonode/blob/master/geonode/layers/utils.py#L94>
>         https://github.com/GeoNode/geonode/blob/master/geonode/layers/forms.py#L81
>         <https://github.com/GeoNode/geonode/blob/master/geonode/layers/forms.py#L81>
>         https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L1084
>         <https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L1084>
>         > The questions are:
>         > Is supporting more types / making the upload more generic a
>         planned feature for a future geonode release?
>         > What would be the pros / cons to this approach vs an
>         approach like first converting the upload to a shapefile (like
>         in the layer_upload view), then use the existing upload flow?
>         > Any pain points / gotchas in the above approach?
>         > Best regards,
>         > Eric
>         > Novel-T Sàrl
>         > Eric GRÖNING - Solutions Engineer
>         > W: www.novel-t.ch
>         <http://www.novel-t.ch><http://www.novel-t.ch/
>         <http://www.novel-t.ch/>> | @: eg at novel-t.ch
>         <mailto:eg at novel-t.ch><mailto:eg at novel-t.ch
>         Hi Eric,
>         This project is for making uploads generic:
>         https://github.com/geonode/django-osgeo-importer
>         <https://github.com/geonode/django-osgeo-importer> and we're
>         going to be
>         working on FGDB support.  The approach you outlined looks
>         good, I'd just
>         suggest doing it as part of the importer.
>         Cheers,
>         Jivan Amara
>         Senior Software Developer / System Administrator
>         Development at JivanAmara.net
>         _______________________________________________
>         geonode-devel mailing list
>         http://lists.osgeo.org/mailman/listinfo/geonode-devel
>         <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>     Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161212/5c1773d4/attachment.html>
More information about the geonode-devel mailing list
