[GeoNode-devel] Finding unminified geonode.js
Simone Dalmasso simone.dalmasso at gmail.com
Wed Feb 3 05:31:53 PST 2016
Yes, geonode.js is not actually used and is an old dinosaur.
Take a look at
https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js
 and
https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js.
Not sure if these are the right places but maybe you can add your code
there.
For sure Bart can tell you much more than me
2016-02-03 14:01 GMT+01:00 Jeffrey Johnson <ortelius at gmail.com>:
> Hi Marc,
> This is puzzling why this file is only in minified form, but if Im not
> mistaken, this is this set of files from long ago in GeoNode's history and
> I dont believe any of it is actually used anymore.
> https://github.com/GeoNode/geonode/tree/362015725f6f4bc0633d31e4d35dc7fbd6359568/src/geonode-client/app/static/script/app/GeoNode
> Bart or Simone, can either of you take a quick look? Perhaps we can just
> remove this and not load it at all.
> I believe you would want to add your tool around here, but ext is not my
> forte, so again we should rely on Bart or perhaps Simone for an answer to
> that.
> https://github.com/GeoNode/geonode/blob/24677dee2d23cf83717968497344b3437167e85f/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js#L409
> Jeff
> On Wed, Feb 3, 2016 at 1:49 PM, BARAT, Marc <marc.barat at capgemini.com>
> wrote:
>> Hi all,
>> I am looking for an unminified version of the geonode.js file (
>> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode.js
>> In fact I’m trying to extend the viewer functionality.
>> To be more precise I’d like to add a free hand drawing tool to the
>> toolbar :
>> Is there a simply way to achieve that  to your knowledge?
>> Best regards
>> Marc
>> This message contains information that may be privileged or confidential
>> and is the property of the Capgemini Group. It is intended only for the
>> person to whom it is addressed. If you are not the intended recipient, you
>> are not authorized to read, print, retain, copy, disseminate, distribute,
>> or use this message or any part thereof. If you receive this message in
>> error, please notify the sender immediately and delete all copies of this
>> message.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160203/201e039b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160203/201e039b/attachment.png>
More information about the geonode-devel mailing list
