[GeoNode-devel] Broken Build
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Feb 3 10:04:13 PST 2016
Hello Jeffrey,
I can try to have a look even if I really don't understand how this commit
could break the build.
Let me do some tests,
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Feb 3, 2016 at 1:51 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Hi Guys,
> Looks like Alessios recent docs changes broke the build somehow. See here.
> https://travis-ci.org/GeoNode/geonode/builds
> Looks to be related to shapely somehow.
> Strangely enough it looks like the packages are pegged to 1.3.1 which
> is quite old by now (see https://pypi.python.org/pypi/Shapely)
> Alessio, I dont think this has anything to do with the docs changes,
> but could you take a look and see if you can figure out what happened?
> Thanks,
> Jeff
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160203/f4b9e6c7/attachment.html>
More information about the geonode-devel mailing list
