[GeoNode-devel] Broken Build
Jeffrey Johnson ortelius at gmail.com
Wed Feb 3 10:19:08 PST 2016
This returns the build to a passing state, but this is a very old
shapely. See the log here. https://pypi.python.org/pypi/Shapely
1.3.1 is from 2014-04-22 and the latest update is 1.5.13 (2015-10-09)
... so not sure whats up here ... at least its not failing now.
On Wed, Feb 3, 2016 at 10:06 PM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> I just pushed a potential fix, as we do pip install this was getting an
> updated shapley higher that the package so for now is bound to 1.3.1.
> Probably they released a new shapley on pypi in the last weeks.
> We can upgrade it it's required by geonode
> 2016-02-03 19:04 GMT+01:00 Alessio Fabiani
> <alessio.fabiani at geo-solutions.it>:
>> Hello Jeffrey,
>> I can try to have a look even if I really don't understand how this commit
>> could break the build.
>> Let me do some tests,
>> Alessio.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, Feb 3, 2016 at 1:51 PM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> Hi Guys,
>>> Looks like Alessios recent docs changes broke the build somehow. See
>>> here.
>>> https://travis-ci.org/GeoNode/geonode/builds
>>> Looks to be related to shapely somehow.
>>> Strangely enough it looks like the packages are pegged to 1.3.1 which
>>> is quite old by now (see https://pypi.python.org/pypi/Shapely)
>>> Alessio, I dont think this has anything to do with the docs changes,
>>> but could you take a look and see if you can figure out what happened?
>>> Thanks,
>>> Jeff
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
More information about the geonode-devel mailing list
