[GeoNode-devel] DJango 1.7.11 & Backup-and-Restore
Ariel Nunez ingenieroariel at gmail.com
Thu Feb 18 06:14:57 PST 2016
Hi alessio,
Thanks for this effort. I believe we should target Django 1.8.7 (the one
shipping in Xenial), both Django and that Ubuntu version are LTS.
It should be fine to update to Django 1.7 and then Django 1.8 hopefully
soon too.
Thank you!
Ariel.
On Thu, Feb 18, 2016 at 6:17 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> while trying to fix the issues with the GeoNode model when deserializing
> the Layers from JSON fixtures, I spent a considerable time trying to
> convert GeoNode to DJango 1.7.11.
> The bad news are that upgrading GeoNode to DJango 1.7.11 does not fix the
> problem, the good ones is that I can now provide a patch (the one attached
> for 2.4.x) to upgrade GeoNode to DJango 1.7.11.
> I'm going to attach the patch here if anyone would like to take a look or
> test it.
> If the community wants to do the update, I can open a pull request.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160218/985fb652/attachment.html>
More information about the geonode-devel mailing list
