[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel
rodrigo.esquivel at gmail.com
Thu Feb 18 17:04:04 PST 2016
Hi Simone, thanks for the advice now the system can download csv files
without any problem but still can not display the layer, Tried to download
a kml file or jpg and I have a "not properly configured datastore" error( I
think that they are related errors). Any other place that I have to look
at?
Best Regards and thanks for your time,
Rodrigo
On Wed, Feb 17, 2016 at 7:49 AM, Rodrigo Esquivel <
rodrigo.esquivel at gmail.com> wrote:
> Thanks for your help Simone, I will start from scratch applying what you
> wrote me and I will let you know of anything else.
> Rgds
> Rodrigo Esquivel
> On Mon, Feb 15, 2016 at 2:10 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> in the geoseerver admin, put the correct credentials in the definition of
>> the store that geoserver is using to connect to postgres. This happens if
>> the postgres password has been changed during the restore.
>> 2016-02-14 22:50 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>> Just as an update of this issue. I tried to use the geonode database
>>> user password generated in the server where the backups are generated in
>>> the server I use as a test but then the application crashes, I checked in
>>> the error log of the apache and says "authentication failed". Rgds
>>> Rodrigo
>>> On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
>>>> Thanks Simone, I appreciate your patience and time spent with me. The
>>>> thumbs are appearing but now I do not have the layer itself in the map( see
>>>> attached file), touching here and there also noticed that when I try to
>>>> download the layer I have an authentication error. I suspect that they are
>>>> both sides of the same problem. What do you recommend to check?
>>>> Best Regards from Panama,
>>>> Rodrigo Esquivel
>>>> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
>>>>> the thumbnails are saved in /var /www/geonode. if you restore that one
>>>>> you'll get them back.
>>>>> hope it helps
>>>>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com
>>>>>> Good night .. thanks for the advice it seems that somehow the first
>>>>>> dump I generated was corrupted. I generated a new one, restored it and I
>>>>>> didn't have any problem accessing the application. However even though I
>>>>>> have access to the layers, the preview is not appearing( see
>>>>>> troubleshootingrestore.png) Looking in older mails I thought that the
>>>>>> problem could be in the web.xml or in the local_settings.py, but both
>>>>>> seemed normal to me so I suspect that besides the subdirectories
>>>>>> /usr/share/geoserver/data and /var/lib/geoserver I have to take in account
>>>>>> another one.
>>>>>> Thanks for your Time,
>>>>>> Rodrigo Esquivel
>>>>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>>>>> Hi,
>>>>>>> the error tells that either your db is not configured with postgis
>>>>>>> (but if you have restored then it should be) of you have to add
>>>>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <
>>>>>>>> Hello All, I am making some backup and restore tests. I followed
>>>>>>>> all the information I found in the net: Backup of the Database and the
>>>>>>>> files in the directories /usr/share/geoserver/data and
>>>>>>>> /var/lib/geoserver/geonode-data. After I restore the Data Base backup and
>>>>>>>> the sub-directories I have an error 500 when I try to run the application.
>>>>>>>> The Apache's log is telling me that there is some file that do not have
>>>>>>>> permission to be accessed( I am attaching the file) I am using Geonode R
>>>>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
>>>>>>>> else I need to do? Thanks in advance for your time.
>>>>>>>> Rodrigo Esquivel
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> Simone
>>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160218/a9c0158d/attachment-0001.html>
Name: Screenshot - 18022016a.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160218/a9c0158d/attachment-0001.png>
More information about the geonode-devel
