[GeoNode-devel] Problems restoring Geonode Data
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Feb 19 08:38:41 PST 2016
Rodrigo,
if you go at the GeoServer > Layer Preview and click
on geonode:barriosvivienda_3, are you able to see it into the map?
Unfortunately from the logs I cannot see the real cause, but I guess that
the problem is on the layer.
You can also check if in you Database "geonode_imports" (depending on your
local_settings.py) there exists a table called "barriosvivienda" and has
records.
Maybe the issue is caused by the fact the the table somehow is empty.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Fri, Feb 19, 2016 at 5:28 PM, Rodrigo Esquivel <
rodrigo.esquivel at gmail.com> wrote:
> Hello Alessio: I am sending the log comprised, hope it can help; what I
> made today was to try to open a layer and try to download a file from it,
> so you can check the logs dated on Feb 19th, 2016. Just to give you a
> context I am running Geonode R 2.01 on Ubuntu 12.04. I am also sending the
> data store screenshots in case it can help. As always, thanks to you and
> Simone for your time.
> Rgds
> Rodrigo
> On Fri, Feb 19, 2016 at 10:13 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Rodrigo,
>> if you have admin rights to GeoNode, go to the GeoServer administration
>> page, click on " Settings > Global " and select "VERBOSE_LOGGING" profile.
>> Save and try to make a query again.
>> Go back to the GeoServer administration page, click on " GeoServer logs "
>> and try to catch the Exception Stacktrace. You can also download the file,
>> compress it and send here in order to take a look.
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Feb 19, 2016 at 4:05 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> There must be something missing the datastore definition. Any error in
>>> the geoserver datastore admin panel?
>>> 2016-02-19 2:04 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>>> Hi Simone, thanks for the advice now the system can download csv files
>>>> without any problem but still can not display the layer, Tried to download
>>>> a kml file or jpg and I have a "not properly configured datastore" error( I
>>>> think that they are related errors). Any other place that I have to look
>>>> at?
>>>> Best Regards and thanks for your time,
>>>> Rodrigo
>>>> On Wed, Feb 17, 2016 at 7:49 AM, Rodrigo Esquivel <
>>>>> Thanks for your help Simone, I will start from scratch applying what
>>>>> you wrote me and I will let you know of anything else.
>>>>> Rgds
>>>>> Rodrigo Esquivel
>>>>> On Mon, Feb 15, 2016 at 2:10 AM, Simone Dalmasso <
>>>>>> in the geoseerver admin, put the correct credentials in the
>>>>>> definition of the store that geoserver is using to connect to postgres.
>>>>>> This happens if the postgres password has been changed during the restore.
>>>>>> 2016-02-14 22:50 GMT+01:00 Rodrigo Esquivel <
>>>>>>> Just as an update of this issue. I tried to use the geonode database
>>>>>>> user password generated in the server where the backups are generated in
>>>>>>> the server I use as a test but then the application crashes, I checked in
>>>>>>> the error log of the apache and says "authentication failed". Rgds
>>>>>>> Rodrigo
>>>>>>> On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
>>>>>>>> Thanks Simone, I appreciate your patience and time spent with me.
>>>>>>>> The thumbs are appearing but now I do not have the layer itself in the map(
>>>>>>>> see attached file), touching here and there also noticed that when I try to
>>>>>>>> download the layer I have an authentication error. I suspect that they are
>>>>>>>> both sides of the same problem. What do you recommend to check?
>>>>>>>> Best Regards from Panama,
>>>>>>>> Rodrigo Esquivel
>>>>>>>> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
>>>>>>>>> the thumbnails are saved in /var /www/geonode. if you restore that
>>>>>>>>> one you'll get them back.
>>>>>>>>> hope it helps
>>>>>>>>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <
>>>>>>>>>> Good night .. thanks for the advice it seems that somehow the
>>>>>>>>>> first dump I generated was corrupted. I generated a new one, restored it
>>>>>>>>>> and I didn't have any problem accessing the application. However even
>>>>>>>>>> though I have access to the layers, the preview is not appearing( see
>>>>>>>>>> troubleshootingrestore.png) Looking in older mails I thought that the
>>>>>>>>>> problem could be in the web.xml or in the local_settings.py, but both
>>>>>>>>>> seemed normal to me so I suspect that besides the subdirectories
>>>>>>>>>> /usr/share/geoserver/data and /var/lib/geoserver I have to take in account
>>>>>>>>>> another one.
>>>>>>>>>> Thanks for your Time,
>>>>>>>>>> Rodrigo Esquivel
>>>>>>>>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>>>>>>>>> Hi,
>>>>>>>>>>> the error tells that either your db is not configured with
>>>>>>>>>>> postgis (but if you have restored then it should be) of you have to add
>>>>>>>>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>>>>>>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <
>>>>>>>>>>>> Hello All, I am making some backup and restore tests. I
>>>>>>>>>>>> followed all the information I found in the net: Backup of the Database
>>>>>>>>>>>> and the files in the directories /usr/share/geoserver/data and
>>>>>>>>>>>> /var/lib/geoserver/geonode-data. After I restore the Data Base backup and
>>>>>>>>>>>> the sub-directories I have an error 500 when I try to run the application.
>>>>>>>>>>>> The Apache's log is telling me that there is some file that do not have
>>>>>>>>>>>> permission to be accessed( I am attaching the file) I am using Geonode R
>>>>>>>>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
>>>>>>>>>>>> else I need to do? Thanks in advance for your time.
>>>>>>>>>>>> Rodrigo Esquivel
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>> Simone
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160219/d21bd8df/attachment-0001.html>
More information about the geonode-devel
