[GeoNode-devel] DJango 1.8.7
Simone Dalmasso simone.dalmasso at gmail.com
Sun Feb 21 23:18:13 PST 2016
I'm +1 on the patch then. Thanks Alessio
2016-02-19 15:28 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Patches are ready and working.
> The one only remark is to pay attention when initializing the DB.
> With DJango 1.8.7 using PostgreSQL as backend, you need to run migrations
> before syncdb, otherwise you'll get an error about a non existant relation
> on the DB.
> *python manage.py makemigrations*
> *python manage.py migrate sites*
> *python manage.py migrate auth*
> *python manage.py migrate contenttype*
> *paver sync*
> Everything works smoothly with the default backend instead.
> The pathces to apply are 3:
> 1. To geonode-announcements project which must be installed on the virtual
> env
> 2. To geonode-ratings project which must be installed on the virtual env
> 3. To geonode
> Upgrading to DJango 1.8.7 does not resolve the issue with GeoNode model
> for the Backup&Restore, so, unless we agree on apply the patch to the model
> I proposed some time ago, the PR is currently BLOCKED.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160222/3a5dcd02/attachment.html>
More information about the geonode-devel mailing list
