[GeoNode-devel] [OSGeo-Discuss] Starting the build process for OSGeo-Live 9.5
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Jan 10 09:49:22 PST 2016
Thanks!
On Sun, Jan 10, 2016 at 7:39 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> I just added you on Launchpad as an administrator.
> Thanks Angelos!
> -a
> On Sun, Jan 10, 2016 at 12:14 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> Hi all and Happy New Year,
>> I just finished porting the GeoNode OSGeo PPA to 2.4 final.
>> The packages can be found here:
>> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/geonode/+packages
>> Some details:
>> 1. I removed all explicit dependencies to geoserver and postgis.
>> 2. The configuration is done through a shell script:
>> https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
>> 3. The python-django package provided in our stable ppa is not done
>> properly, the django-admin binary is missing. I backported django 1.6.11 to
>> trusty here:
>> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+sourcepub/5949521/+listing-archive-extra
>> This new django package is not tested yet, will test in next OSGeoLive
>> nightly build.
>> So far, GeoNode 2.4 is working as expected in OSGeoLive nightly build15
>> along with GeoServer 2.7.5 and django 1.6.1:
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build15-amd64-a341ee0.iso
>> The issue regarding loading vector layers has been fixed! Will update the
>> ticket.
>> What would be the best way to proceed? Should we wipe out GeoNode OSGeo
>> PPA or should we use another PPA? I would recommend to delete the GeoNode
>> OSGeo PPA and re-create it with the new packages. Unfortunately I do not
>> have permissions for this, can someone please add me to the maintenance
>> team?
>> Best,
>> Angelos
>> On Tue, Nov 24, 2015 at 3:29 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>> wrote:
>>> Thanks Ariel for the feedback,
>>> I will have some free time to work on this in about 2 weeks.
>>> Best,
>>> Angelos
>>> On 11/24/2015 03:02 PM, Ariel Nunez wrote:
>>>> We do not use "our" debian package for osgeo live, but all the
>>>> dependencies
>>>> are packaged as deb files. The python-geonode debian package is not the
>>>> same as the geonode debian package, python-geonode does not do any
>>>> configuration, just defines the python based dependencies and installs
>>>> the
>>>> python code.
>>>> There is an installation script in the osgeo live dvd for GeoNode, it
>>>> could
>>>> use a template project or not, and it uses a shared apache server in
>>>> there.
>>>> The tasks to be done would be:
>>>> 1. Copy all the new dependencies from stable to the osgeo ppa.
>>>> 2. Create a new python-geonode package based on the current one in that
>>>> ppa
>>>> (download that package with apt-source and reuse the control file, use
>>>> the
>>>> geonode 2.4 artifact in pypi).
>>>> 3. Run the osgeo live dvd with the updated packages
>>>> 4. Look into the reported bug of layers not loading that is reported in
>>>> the
>>>> osgeo tracker, make a point release if any bug is found and fixed.
>>>> 5. Rinse and repeat.
>>>> Unfortunately, I do not have time in the next month to help with this,
>>>> but
>>>> I am happy to answer any questions about it.
>>>> -a
>>>> On Mon, Nov 23, 2015 at 11:18 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>> wrote:
>>>> I wonder if we should go about this a bit differently and just run a
>>>>> template project with swgi and not bother with packages, connecting to
>>>>> the existing GeoServer. Ariel thoughts?
>>>>> On Mon, Nov 23, 2015 at 8:12 AM, Angelos Tzotsos <
>>>>> wrote:
>>>>>> Cool, we should cherry-pick packages from stable ppa to the osgeo ppa
>>>>> that
>>>>>> Ariel setup some time ago.
>>>>>> Then we need a modification in python-geonode not to pull the
>>>>>> geoserver
>>>>> deb
>>>>>> file...
>>>>>> On 11/23/2015 06:09 PM, Jeffrey Johnson wrote:
>>>>>>> Sorry I missed it on Gitter during the sprint. I think we can go with
>>>>>>> totally vanilla geoserver and just disable permissions completely
>>>>>>> from
>>>>>>> the UI and do updatelayers with the local geoserver.
>>>>>>> On Mon, Nov 23, 2015 at 8:06 AM, Angelos Tzotsos <
>>>>>>> wrote:
>>>>>>>> With some guidance from Ariel, I can try.
>>>>>>>> We need to use vanilla geoserver (this is why I asked in gitter
>>>>>>>> during
>>>>>>>> the
>>>>>>>> code sprint :)
>>>>>>>> Best,
>>>>>>>> Angelos
>>>>>>>> On 11/23/2015 05:13 PM, Jeffrey Johnson wrote:
>>>>>>>>> Are we going to try to upgrade the geonode on osgeolive? If so, who
>>>>>>>>> has time to help with this?
>>>>>>>>> On Sun, Nov 22, 2015 at 11:18 AM, Cameron Shorter
>>>>>>>>> <cameron.shorter at gmail.com> wrote:
>>>>>>>>>> We are starting the build cycle for version 9.5 of the OSGeo-Live
>>>>>>>>>> [1]
>>>>>>>>>> DVD/USB/VM which will be released in March 2016, ready for several
>>>>>>>>>> special
>>>>>>>>>> events, including FOSS4G-NA, FOSSGIS (Salzburg, Austria), among
>>>>>>>>> others.
>>>>>> We would like to hear from anyone wishing to add new projects to
>>>>>>>>>> OSGeo-Live,
>>>>>>>>>> anyone wishing to extend or add translations, or anyone who has
>>>>>>>>>> ideas
>>>>>>>>>> on
>>>>>>>>>> how
>>>>>>>>>> we should shape the upcoming release.
>>>>>>>>>> Key Milestones
>>>>>>>>>> 11 Jan 2016 All new applications installed, most old applications
>>>>>>>>>> updated
>>>>>>>>>> 01 Feb 2016 Feature Freeze (all apps updated)
>>>>>>>>>> 15 Feb 2016 User Acceptance Test (all apps installed and working)
>>>>>>>>>> 21 Mar 2016 Final ISO sent to printers
>>>>>>>>>> About OSGeo-Live
>>>>>>>>>> OSGeo-live is a Lubuntu based distribution of Geospatial Open
>>>>>>>>>> Source
>>>>>>>>>> Software, available via a Live DVD, Virtual Machine and USB. You
>>>>>>>>>> can
>>>>>>>>>> use
>>>>>>>>>> OSGeo-Live to try a wide variety of open source geospatial
>>>>>>>>>> software
>>>>>>>>>> without
>>>>>>>>>> installing anything.
>>>>>>>>>> [1] http://live.osgeo.org
>>>>>>>>>> Cameron Shorter,
>>>>>>>>>> Software and Data Solutions Manager
>>>>>>>>>> LISAsoft
>>>>>>>>>> Suite 112, Jones Bay Wharf,
>>>>>>>>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>>>>>>>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Discuss mailing list
>>>>>>>>>> Discuss at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/discuss
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> Angelos Tzotsos, PhD
>>>>>>>> OSGeo Charter Member
>>>>>>>> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160110/8153df10/attachment.html>
More information about the geonode-devel mailing list
