[GeoNode-devel] Django 1.9 compatibility
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Jan 12 06:28:51 PST 2016
Ubuntu Xenial has django 1.8 so far.
https://launchpad.net/ubuntu/xenial/+source/python-django
On Tue, Jan 12, 2016 at 4:17 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> Karma,
> It boils to two things, imho:
> 1. Dependency on a lot of third party django packages means upgrading when
> all those are upgraded or having to maintain forks.
> 2. Using Ubuntu LTS means waiting two years before jumping versions on the
> production recommendations.
> The actual issues found on each upgrade are usually not that bad and
> require minor modifications to GeoNode's code base.
> Now that we are in the area, do you know what the next Ubuntu LTS is
> shipping with?
> -a
> On Tue, Jan 12, 2016 at 8:33 AM, Karma Kolabor <collaborista at gmail.com>
> wrote:
>> I would be very interested in reading more about the update / upgrade
>> process - please make notes about the problematic areas and it would
>> be very appreciated if you could publish your notes and how you got
>> around the problems in a blog post or anything else.
>> This is more about general problems with django in longterm projects -
>> I see many project that seem to be stuck on old versions - I would
>> like to find out more about the reasons for this phenomen.
>> Thanks for your attention,
>> Karma
>> On Wed, Jan 6, 2016 at 10:22 AM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>> > Hi.
>> > I don't think that anyone has tried it yet. What kind of issues are you
>> > facing? We are definitely interested in upgrading django and will try to
>> > give you support.  Happy to receive PRs as well :)
>> > Il martedì 5 gennaio 2016, Jiehua Chen <j at qed.ai> ha scritto:
>> >> Hi all,
>> >> Anyone worked on make geonode compatible with Django 1.9? We are also
>> >> trying to do that.
>> >> Best,
>> >> Jiehua Chen, Ph.D.
>> >> QED | http://qed.ai
>> > Simone
>> > _______________________________________________
>> > geonode-devel mailing list
>> > geonode-devel at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-devel
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160112/447575a5/attachment.html>
More information about the geonode-devel mailing list
