[GeoNode-devel] AuthenticationServiceException: Communication with GeoNode failed Caused by: java.net.SocketTimeoutException: Read timed out
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 18 01:34:42 PST 2016
Not as far as I know unless there is something on the server preventing
that.
2016-01-18 10:09 GMT+01:00 Ken Abryl Eleazar Salanio <
kasalanio at dream.upd.edu.ph>:
> Yep, I've edited the config.xml to specify the geonode base location. If
> the location cannot be found, geoserver outputs a "Caused by:
> java.net.UnknownHostException: <hostname>". However in this case, it's a
> socket timeout. Geoserver sees the location, but cannot finish the
> authentication. Is it possible that apache or java blocks the connection
> until it times out?
> On Mon, Jan 18, 2016 at 4:48 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi,
>> yes is in the geoserver data
>> dir/security/auth/geonodeAuthProvider/config.xml. There you have to put the
>> Regards
>> 2016-01-18 9:47 GMT+01:00 Ken Abryl Eleazar Salanio <
>>> WARN [geonode.security] - Error connecting to the GeoNode server for
>>>> authentication purposes
>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>> at
>>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>>>> at
>>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>>>> at
>>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>>>> at
>>>> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>>>> at
>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>>>> at
>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>>> at
>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>>>> at
>>>> at
>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>> at
>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>> at
>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>>>> at
>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>> at
>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>> at
>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>> at
>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>> at
>>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>>>> at
>>>> at
>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>>>> at
>>>> at
>>>> at
>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>> at
>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>> at
>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>> at
>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>> at
>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>> at
>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>> at
>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>> at
>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>> at
>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>> at
>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>> at
>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>> at
>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>> at
>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>> at java.lang.Thread.run(Thread.java:745)
>>>> at java.net.SocketInputStream.socketRead0(Native Method)
>>>> at java.net.SocketInputStream.read(SocketInputStream.java:152)
>>>> at java.net.SocketInputStream.read(SocketInputStream.java:122)
>>>> at java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
>>>> at java.io.BufferedInputStream.read(BufferedInputStream.java:254)
>>>> at
>>>> org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78)
>>>> at
>>>> org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106)
>>>> at
>>>> org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116)
>>>> at
>>>> org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnectionManager.java:1413)
>>>> at
>>>> org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973)
>>>> at
>>>> org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
>>>> at
>>>> org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
>>>> at
>>>> org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
>>>> at
>>>> org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
>>>> at
>>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>>>> at
>>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>>>> at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:70)
>>>> at
>>>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>>>> at
>>>> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>>>> at
>>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>>>> ... 47 more
>>> My question is, what geonode URI does geoserver use for authentication,
>>> so that I may check if it is being blocked somewhere? Thanks!
>>> On Mon, Jan 18, 2016 at 4:45 PM, Ken Abryl Eleazar Salanio <
>>> kasalanio at dream.upd.edu.ph> wrote:
>>>> Hi, I've installed a development version of geonode and i'm running the
>>>> geoserver using tomcat 7. It worked for quite a while but I've recently
>>>> encountered this error and can't seem to debug it:
>>>> Ken Abryl Eleazar S. Salanio
>>>> *Computer Programmer III*
>>>> *Data Archiving and Distribution Component*
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160118/aa38cbcc/attachment-0001.html>
More information about the geonode-devel
