[GeoNode-devel] [GeoNode-users] GeoNode Windows installer: looking for testers
Jeffrey Johnson
ortelius at gmail.com
Mon Jan 18 03:14:57 PST 2016
Alessio,
Thanks for posting this. I do think its important that we install
PostGIS in this installation and configure the vector data layers to
be loaded to a PostGIS backed Data store. Can we go ahead and make
those changes.
Thanks,
Jeff
On Mon, Jan 18, 2016 at 1:48 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> at this address
> https://www.dropbox.com/s/ujclwt7mtu5zy87/GeoNode-2.4.exe?dl=0
> you can find a first version of the GeoNode Windows installer.
> The installer has been created using NSIS compiler and if it works fine it
> will be part at the official GeoNode distribution and continuous build as a
> result of the folowing GNIP:
> https://github.com/GeoNode/geonode/issues/2375
> The installer works by installing under a folder chosen by the user:
> 1. A 32bit version of JRE 1.8
> 2. A 32bit version of Python 2.7.10 with virtualenv and GDAL bindings
> 3. A 32bit version of Apache Tomcat 7.0.35 with GeoServer
> 4. A customized version of minimal WinLAMP with only the Apache HTTPD +
> mod_wsgi
> At the end of the installation you should be able to see:
> 1. A running service of Apache Tomcat for GeoServer
> 2. A running service of Apache HTTPD server for GeoNode
> Your GeoNode installation will be available at:
> http://localhost
> Your GeoServer installation will be available at:
> http://localhost/geoserver
> No DB is installed on this version. The installation relies on the default
> GeoNode settings.
> It could be possible to optionally install also PostGIS in the future if the
> community really needs it.
> Also notice that the GeoNode will be configured to run in production mode
> through the mod_wsgi and not in development mode through paver.
> Please test it and report any feedbacks.
> Very soon I will make available the NSIS source code too.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-devel
